LG Plasma TV 50PA6500 vertical lines
  • Jever2000
    • Feb 2016
    • 10
    Hello Guys,
    i have a TV that has max 40h of usage (Office Monitor).
    The next day, it has well defined vertical lines.
    I doubt, it's the logic board (or T-con).
    Can anybody confirm this ?
    Sound comes nicely, and channels are switchable, only the lines remain.
    Even entering the menu doesn't change the picture.
    Please find attached some pictures.
    Any help is highly appreciated.
    Thanks, Jan
    PS: In case... can i use a Rev. 1.1 board instead of the mounted Rev. 1.0 ? (same LG part no. for both)
  • dcapper
    • Dec 2013
    • 496
    Re: LG Plasma TV 50PA6500 vertical lines
    Can you take the back off and take some pictures of the boards for us?
    • Jever2000
      • Feb 2016
      • 10
      Thanks for the quick reply!
      Yes, i can do so tomorrow.
      However, i think it's such a distinct failure,
      someone might know what's the cause.
      I'll post pics tomorrow.
      Thanks, Jan
      • Jever2000
        • Feb 2016
        • 10
        Ok, with a little delay, here's the picture.
        IThe logoc board is the small one in the middle.
        For LG spare parts, what is the relevant number, EBR or EAX ?
        Thanks, Jan
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          I have a t-con board for a 50pn6550. And the main board.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Look up on how to run the test patterns on Lg plasmas. I would say mobo at fault here.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              I made a mistake. The tcon and main board I have are from a 60pA6500ua
              • Jever2000
                • Feb 2016
                • 10
                I disconnected the Mainboard and shortened the ext_auto_gen pins on the logic board.
                The stripes remain, or better appear, when the pins are shortened.
                So i suspect, the Mainboard is OK.
                What about the Y-SUS ?
                Regards, Jan
                PS: i just measured some Voltages:
                Y-SUS:
                VY=190V
                VSC=150,7 V
                Power Supply:
                VS=205,4 V
                VA=55,6 V
                VZB=149,9 V
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Control-board fault.
                  TELEFIX
                  • tw2005
                    • Oct 2011
                    • 6458
                    Ditto, I'd be thinking logic ctrl board especially if it remains with the mainboard isolated and the auto-gen enabled
                    • Jever2000
                      • Feb 2016
                      • 10
                      Ok, i think i'll replace it.
                      I have an EAX, an EBR and a revision on the board.
                      Do all three have to match ?
                      Thanks.
                      • tw2005
                        • Oct 2011
                        • 6458
                        most likely the EBR number, the EAX could be just the PCB number, the white sticker would be the one I'd go with.
                        • Jever2000
                          • Feb 2016
                          • 10
                          Ok, guys!
                          I finally ordered a new logic board for .... 6$ (18$ postage to Germany), and ......
                          IT WORKED
                          The pattern is still a bit visably when the screen is black, but i hope this will disappear over time.
                          THX to all supporting!
                          Jan
                          • mmartell
                            • Oct 2013
                            • 3189
                            Yes you may have some retention (hopefully not burn in!) Running it for a while should cure it.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Awesome, just a little IR wont take long to clear
                              • Jever2000
                                • Feb 2016
                                • 10
                                Stripes are gone after letting my wife watch Downton Abbey
                                • Stanley1843
                                  by Stanley1843
                                  06-29-2024, 11:54 AM
                                • afex
                                  Samsung Plasma TV with vertical lines (model PN50B430P2D)
                                  by afex
                                  This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                                  This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                                  I have attached an image of the TV with these bars displaying....
                                  11-08-2021, 09:23 PM
                                • Falki
                                  Colorful LCD Vertical Lines on Samsung ue55es8090
                                  by Falki
                                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                                  A similar issue has been posted as well but also with no actual response ...
                                  Yesterday, 04:19 AM
                                • visionbluedemon
                                  Help. Sony kd-65x85dj vertical lines
                                  by visionbluedemon
                                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                  tried blocking LC lines too, but same results
                                  is it lcd panel issue or tcon board issue?...
                                  07-25-2025, 04:56 AM
                                • thetonywarren
                                  Samsung PN51E450 Plasma Vertical Lines
                                  by thetonywarren
                                  Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
                                  Any help would be appreciated.....Please let me know.......
                                  02-14-2022, 01:23 PM
