samsung ln-t4069f power issue
  • whitesnake
    • Dec 2013
    • 24
    Just got that samsung TV for free and in the process to figure out what is going on.When the tv start,the screen slowly become white like clouds,then nothing happens.After 7 to 15 attempts the screen light up and the unit work fine.
    I was aware of the capacitor issue so i replace 6 of them: 4X 10v 1000uf and 2X 25v 1000uf but it diden't solve the issue.
    Any idea what to look for?I search for hours but could not pinpoint anything.
  • Jonny g
    • Jan 2016
    • 13
    Re: samsung ln-t4069f power issue
    Did you check all capacitors? I had this issue a few years back and I had missed one.
    • whitesnake
      • Dec 2013
      • 24
      there where 3 that i left there,two small one and a huge one in the middle of the PS.They looked ok and i never seen these one bulged in my search
      • Jonny g
        • Jan 2016
        • 13
        Just double check all, see if any bulge at all. To me sounds like a faulty capacitor as you keep attempting to turn it on, build up a charge, then it works fine.
        • whitesnake
          • Dec 2013
          • 24
          Can a tiny cap can cause these kind of issues?TBH i did not notice if they where buldged so i will open the case and double check.
            Bad caps can look normal but it have high ESR or lost its capacitance. Let the TV cool down then heat up the power supply board with hair dryer for 3~4 minutes then plug the TV and turn it on, if it is still bad then I would take the DCV readings on the power supply connector pins on the cold side, the DCV on the T-CON fuse, then if the TV starts working again then take the DCV reading to see what the difference you get.
            You should also up load good clear pictures of the whole back side of the TV so we can see all the boards.
            • whitesnake
              • Dec 2013
              • 24
              ok thnks for your help tomorrow i will open the case and upload clear pictures and try to give you the readings you ask for.
              • whitesnake
                • Dec 2013
                • 24
                ok back at home i blew some heat like mentioned but still the same symptoms.I took the best shots i could with my iphone.If you need any more info i will try to provide it asap.I will tcheck dc voltage now and send the results later.Yhanks for your help!
                • Kjell
                  Samsung Series 9 - BIOS issue
                  by Kjell
                  After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                  Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                  08-01-2025, 09:15 AM
                  09-07-2024, 05:50 AM
                • vincentedel
                  Samsung SyncMaster 740n Phase Control Issue
                  by vincentedel
                  I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                  I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                  04-22-2025, 12:33 AM
                • Manucsl
                  QE65Q800TATXXC Samsung TV Issue
                  by Manucsl
                  Hello.
                  My TV is a QE65Q800TATXXC Samsung TV.
                  Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                  Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                  Any ideas to check would be very appreciated 😊
                  After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                  02-19-2025, 07:47 AM
                • FourRunner
                  Display issue Samsung TV UA65JS9000W
                  by FourRunner
                  I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                  10-03-2024, 07:05 PM
