Insignia NS-50L440NA14, Backlights Shut Off
  • toddw65
    • Jan 2014
    • 108
    Picked up this tv and it powers on, standby LED flashes red 7 times, backlights come on and display evenly, and then backlights shut off and LED stays green. Nothing on the display with a flashlight. When I first got it, the Insignia logo would come on when powered up, but after a dozen on/off cycles that stopped happening.
    Appreciate your input on this.
    Thanks,
    Todd
  • toddw65
    • Jan 2014
    • 108
    Re: Insignia NS-50L440NA14, Backlights Shut Off
    Gotta love this stuff. I took off the main board to get a pic of the back. While it was out, I hooked it up to check voltages on the back. Lo & behold...the backlight now stays on...even with the board put back in place. And it goes on and off as it should with the power button.
    Now on the the next part of the puzzle.
    Interestingly, voltage to the TCON is 8V and I assumed this would be either 5V or 12V.
      What DCV do you have on that white connector with red and black wire on the FRC (Frame Rate Converter) board (the board sitting between the Tcon and the manin board)?
      • toddw65
        • Jan 2014
        • 108
        5.1V at each red
        • toddw65
          • Jan 2014
          • 108
          I've been trying to research why there is 8V going from the main board ->FRC -> TCON - > Panel. Although I'm a newbie TV repair, 8V just seems unusual to me and I'm thinking it should be 12V. With that in mind I started tracing from the vcc on the connector that goes to the FRC and I'm looking at Q1 on the main board. This looks like where I'm losing my 12v.
            I do expect 12v FOR 50" panel, the switched 12V should be fed through a switched MOSFET which should be on the main board some where close to where the RED/BLK wire connector is.
            You do have 12VDC feeding the main board, right?
            • toddw65
              • Jan 2014
              • 108
              Yes, but it's actually 13v coming from the power board to the main. If I looked it up correctly, I think Q1 is a P channel mosfet.
                It is P-CH because the +13VDC is fed into the Source pin, so for this MOSFET to be on, the Gate DCV must be at least 3V less than the Source pin when TV is powered ON, you can force on this MOSFET but connecting 1K resistor between Gate and circuit ground to see if you will get 13V at the Drain pin.
                Right now the MOSFET is OFF but it may be leaky that is why you are getting 8V even though there is no Bias to turn on the MOSFET.
                You should check the resistance between S and D, G and S, G and D.
                • toddw65
                  • Jan 2014
                  • 108
                  Adding the 1K resistor made no change, but here's what I noticed next. When I disconnected the cable to the FRC, the voltage at the drain pin of Q1 jumped up to 13V and stayed there even when I removed the resistor.
                  I then reconnected the main to FRC board and disconnected the FRC to TCON and the voltage stayed at 13V.
                  Disconnected the panel from the TCON and reconnected the FRC to TCON harness and voltage dropped back to 8v.
                  So the problem appears to be something pulling down the voltage on the TCON.
                    So the Gate Voltage stays at 13VDC when you get 13V at the Drain?
                    Is there a fuse on the T-CON board? You can check the resistance between the fuse and the GND to see if it shows low resistance, or you can try new T-CON board.
                    • toddw65
                      • Jan 2014
                      • 108
                      Yes. 13V at gate & drain. Fuse to ground is infinite so something on the board must be shorted.
                      • toddw65
                        • Jan 2014
                        • 108
                        Got another TCON and put it in and no change. Took out the 3407 MOSFET and since I don't yet have another MOSFET to replace it, I sent 12V to the drain location on the board. Bingo. Fired right up and the menus, picture, and sound all work. New 3407s should be here on Friday. It'll be interesting to see if a new one fixes the issue long term.
                        Thanks for your help Bud!
                        • toddw65
                          • Jan 2014
                          • 108
                          Just wanted to say thanks again. Got the FET in today and she fired right up.
                            Thanks for the follow-up.
                            • toddw65
                              • Jan 2014
                              • 108
                              No problem. Now on to the next conquest.
                              • max789
                                Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                by max789
                                Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                I made the following tests:
                                1. Disconnected the main board from Power Board = backlight works.
                                2. Connected the main board and disconnected the T-Con = backlights does not work.
                                So I ordered a main board from Ebay also BN41-02156A but from...
                                01-18-2024, 06:56 AM
                              • bpcannan
                                VIZIO M557-G0: Backlights or ???
                                by bpcannan
                                'Morning,
                                I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                10-29-2023, 06:36 AM
                              • jesterace
                                Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                by jesterace
                                Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                However, I am in a dilemma.
                                I tested the backlight outputs with the lights disconnected...
                                10-20-2024, 10:15 AM
                              • x_orange90_x
                                Sony KD-75X750H no backlights
                                by x_orange90_x
                                I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                                Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                                07-16-2025, 07:49 PM
                              • jimbofz
                                toshiba 65ul2163 dbl no backlights NOT BACKLIGHTS?
                                by jimbofz
                                Hi this vestel 65in tv had classic no backlights ,so nothing new there!
                                tested with b/l tester and the b/l seemed to be fine
                                so investigated psu 17ips72 (on this 65inch there are 3 fets and control iv type DB83630P)
                                did a thorough check on b/l circuit all ok .
                                When i tried again with b/l tester all ok .but then when i reinstalled psu all worked fine ,
                                could there be a component on psu that is causing the protection mode to stop b/l
                                .maybee causing it to be too sensitive?
                                it seems to me if the b/l have been on with my tester ,within a couple of minutes...
                                06-07-2025, 10:11 AM
