Lg 42pt350r sound no picture
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Hi, please help, lg42pt350r, sound no picture, all voltages correct dc & ripple.
    Have sound, have control via front controls & remote. after running set for a few minutes all heat sinks warm up bar one : the left hand heat sink of the two heat sinks on the ysus.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 42pt350r sound no picture
    If one heat sink is cold likely there is a failed IPM, checked all fuses and VSC ?
    • Grunder
      • Jan 2016
      • 323
      • south africa
      Hi Reecey, VSC i'm guessing is the Vscan? yes 184 volts, and yep fuses ok. The IPM? is that the "impossible-to-remove-with-out-breaking" module usually located under the heat sink? This set dont seem to have the module, but loose components mounted on the hea tsink instead?
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • Mgiffune
        by Mgiffune
        I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
        I ordered a supposedly β€˜new' Tcon board this time, and
        06-09-2024, 10:28 AM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • jchang
        Samsung UN70NU6900F no picture and no sound
        by jchang
        Hi all
        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
        Symptom:
        No picture no sound.
        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
        No sound at all.
        What I tried:
        1. I tried unplugging the left or right ribbon...
        01-09-2023, 06:28 PM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
