Samsung - no standby - already replaced all caps but still
  • vinceroger69
    • Mar 2012
    • 6714
    #41
    Re: Samsung - no standby - already replaced all caps but still
    Data sheet link for the ic
      Check the resistance between Drain and Gnd pins.
      • sciclunam
        • Jan 2016
        • 25
        • Malta
        #43
        With the ic still on board there is no resistance from the GND pin to any of the 3 drain pins.
        Update: removed the IC and still no resistance. Also apart from faulty RB806, also there is no resistance in RB801.
          Rb801 is part of the snubber circuit so it will have resistance in thousands of Ohms, it is more likely to be OK. Like I indicated, you can use 2A fuse in place of the fusible resistor to see if you will get the STBY Voltage back.
          • sciclunam
            • Jan 2016
            • 25
            • Malta
            #45
            OK... so I need to replace the IC and place a 2A fuse instead of RB806. Shall I use a normal 2A fuse (12v?) and solder it in place of RB806 or I can leave RB806 there and solder it underneath?
              You can test the circuit using 2A 250V fuse without replacing the IC, the fuse will bow if the IC is bad, or order new IC, fusible resistor, NTC and put them in and power the TV up through the lamp (75W) in series with the TV LINE (HOT) wire.
              • sciclunam
                • Jan 2016
                • 25
                • Malta
                #47
                SH*t. I removed the IC already and one of the legs got damaged whilst removing it. Maybe I will try and solder a piece of wire instead of the leg. If I do... could you please let me know the exact location where to place the fuse?
                  I would not do that, you might as well replace the parts now instead of taking a chance of damaging the circuits.
                  • sciclunam
                    • Jan 2016
                    • 25
                    • Malta
                    #49
                    Hi all. First of all thanks to your dedication and time (especially budm). Due to time restriction and much more damaged components than I had anticipated in the PSU (some of them are not even available in my country) I was considering buying a new PSU.
                    I have found this supplier in the UK which sells the A version at a good price; ie: BN44-00208A. Mine is B but you said it is compatible right?
                    On their website they have several BN44-00208A all using circuit board PSLF171501B (like mine) but they are version 1.0, 1.1, 1.3 and have different TV model number - all 32 inch. Mine is 26.
                    Will any of these be good for me, ie: to replace BN44-00208B on a 27 inch and which one shall I take? I have asked their customer care and they do not know whether they are compatible or not! These are the items...
                    http://www.lcd-plasma-parts.co.uk/in...rch=bn44-00208
                    Can you pls have a look?
                    • sciclunam
                      • Jan 2016
                      • 25
                      • Malta
                      #50
                      Any help choosing which PSU to buy is appreciated. Thanks
                      • sciclunam
                        • Jan 2016
                        • 25
                        • Malta
                        #51
                        • Shane711
                          • 493
                          I have a Samsung with a BN44-00208B power supply board. I found RB806 (10 ohm fusible Resistor) to be bad, open circuit. I also found RB801 to be reading 340K ohms when it is suppose to be 440K ohms. So I want to replace these.
                          How do I figure out what wattage resistors I need?
                          And I am guessing there is a big difference from a regular resistor and a fusible one.
                          RB806 colors are Brown, Black, Black, Gold, White.
                          RB801 colors are Yellow, Yellow, Yellow, Gold.
                            09-07-2024, 05:50 AM
                          • tvguy12012012120
                            by tvguy12012012120
                            02-07-2025, 05:13 PM
                          • ChristianBr01
                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                            by ChristianBr01
                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                            04-23-2025, 01:48 AM
                          • Kaar3l
                            Samsung QLED QE65Q7FNAT only standby light
                            by Kaar3l
                            TV: Samsung QLED QE65Q7FNAT
                            PSU: BN4400940A
                            MB: BN94-12832K
                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                            09-24-2024, 01:35 PM
                            09-06-2024, 11:40 PM
