Samsung LE40R73BD screen blank with sound
  • cvel
    • May 2015
    • 64
    Hi all I have this tv works for around 30 minutes then the screen goes off but sound still there if I turn it off then straight back on the screen is on again for another half hour. Any help much great fully received
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung LE40R73BD screen blank with sound
    What you say the screen goes off does the backlight stay on ?
    • cvel
      • May 2015
      • 64
      Not that I've noticed just waiting for it to do it again so I can check but pretty sure it's all black
      • sordids999
        • May 2013
        • 2161
        • uk
        Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
        • orinoco8
          • Jan 2016
          • 26
          This unit may have the same problem as mine. No backlight with sound. Similar main board from Samsung. If at all possible, check the INV signal voltage from main board. You may see it drop as the screen goes dark.
          • mrtek
            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
            by mrtek
            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
            11-26-2024, 09:58 AM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • mecha1166
            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
            by mecha1166
            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
            11-25-2024, 05:22 PM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • mar1in
            Samsung TU8000, backlight and sound on, stuck in blue screen
            by mar1in
            I've got this Samsung here that would be stuck in a boot loop.
            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
            Thanks in advance
            11-08-2023, 05:43 PM
