Philips 50PF9631D/37 Half Screen
  • cheebster
    • May 2008
    • 376
    Hello ! I just got this Philips 50PF9631D/37 Plasma, from a customer who was told repair was 1000$ into another shop. I opened the unit up, powered it on after they 'estimated' it, and found a 35V cap soldered upside down. Well, i found out after powering on the display and found it smoking on the power supply.
    So, i replaced that caps, installed it the proper way, and tadam, tv powered on. The owner, first stated the set was dead.
    So now, here's the result i get,
    http://imgur.com/aFLwbfQ
    For some reason, the pictures look like there's some yellow banding, but there's not. There's a yellow huge stain/spot in the middle, and colors are weird in the bad half, but the good half look perfectly black, and then if i press 'menu' i get a very clean meny in half of the tv.
    Anyone got a clue where i could start, could it still be caps related in the psu ?
    I tried using freezeit and heating the psu with a hairdryer, but it didn't make a difference. It's weird, half of the screen is very clean. Any input would be very appreciated, keep in mind i'm a computer technician, just doing these tv's once in a while for fun. Thanks !!!
  • vlado66
    • Apr 2015
    • 10
    • SLOVENSKO
    Re: Philips 50PF9631D/37 Half Screen
    Defective panels
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      I agree bad Panel, possibly will need a Tab bond repair.
      • cheebster
        • May 2008
        • 376
        Really weird. The guy said there was a surge, and it completely stopped working, no power nothing. They had the tv in the repair shop for 6 months !
        When they brought it here, the tv was laying flat in the van. Could it be damage from the transport that caused this ?
        Any cowboy way of doing the tab bond repair, like erasers or something that could give this one some more life ? Thanks for any info !
        • cheebster
          • May 2008
          • 376
          Anyone knows if it's worth it to take it completely apart to look at the tab bonding for possibly fixing, of if it's a waste of time and should go to the recycling as is ? Thanks
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Thats a "defective" panel indeed. They probably already tried to remove the lcd panel from the tv and failed. The tab bonds are damaged.
            You can try to remove the bezel and apply some pressure on the tabs and see if the screen turns back to normal. Its your only option.
              Since this is a plasma I'm not 100% convinced the panel is bad. I would check that the Va fuse on the lower address boards is good. Also, check the cables are seated. Do not unplug or plug in Va with power connected as you may cause damage to the panel (if it ain't already knackered...)
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Rigt you are Tom thought this was an Lcd lol Doh !
                  I didn't even need the model number to tell it's a plasma you can see the blue-yellow banding from the subfields. As seen here in slow motion:
                  https://www.youtube.com/watch?v=yWecqe04DTI
                  if a CMOS camera with a slow shutter takes the picture it'll appear in blue-yellow bars
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Capacitorial
                    Philips 46PFL8007K/12 - Picuture flickers on half of the screen
                    by Capacitorial
                    Hello guys.
                    I recently got a TV that has the following problems:
                    1. Sometimes it has to be turned on and off a few times, to boot up. Sometimes it starts from the first try
                    2. When it is running normally, the right side of the screen flickers. Sometimes it is just a square of transparent white maybe a 1/3 of the right half (top right)
                    3. The flicker is also sometimes a square that is filled with lines
                    4. I noticed that when the TV brightness is set to max, it flickers less. I think the Standard setting is the worst where it comes more frequent
                    5. When it runs a few minutes it gets better,
                    12-17-2023, 11:11 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • valvashon
                    LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                    by valvashon
                    The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                    Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                    11-24-2024, 12:08 PM
                  • Raulnn
                    TD Systems K50DLG12US half black and half white screen
                    by Raulnn
                    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                    01-20-2024, 04:49 PM
