Trying to repair my dad's tv. When I turn unit on, screen will appear showing emerson, then tv shuts off immediately and I can hear a pop coming from speaker each time it shuts off. Tried turning on 5 to 6 times and same thing happened every time. I searched forums and saw another post with same issue but no resolve. Thanks for any help.
LF461EM4 Emerson
by huzoThe model is 15ec-1061nm
Board number is DAG3EDMB8D0​
SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...10-29-2024, 12:05 AM -
by brav1ezHello everyone,
I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
I’ve tried:
- CMOS reset
- Removing the SSD/HDD
- Reseating RAM (removing each stick individually stops boot completely)
- Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
With...09-07-2025, 10:47 AM -
by chaos-theoryI have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and... -
by baglaivladHello everybody!
Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...11-20-2024, 08:14 AM -
by samuelphirikHi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
Now I've noticed that laptop... - Loading...
