Trying to repair my dad's tv. When I turn unit on, screen will appear showing emerson, then tv shuts off immediately and I can hear a pop coming from speaker each time it shuts off. Tried turning on 5 to 6 times and same thing happened every time. I searched forums and saw another post with same issue but no resolve. Thanks for any help.
LF461EM4 Emerson
by huzoThe model is 15ec-1061nm
Board number is DAG3EDMB8D0​
SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...10-29-2024, 12:05 AM -
by Giggle2562Hello everyone,
I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
Here's what I've tried so far:- When the internal display is disconnected, the laptop works perfectly fine via HDMI.
- The laptop shows an image on the internal display for a few seconds before it shuts down.
- I tried swapping the LCD panel with a known good one.
- I tried swapping the LCD cable
by riko 656Hello everyone,
I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
Laptop Model:- Model: Lenovo Legion Slim 5 16APH8
- GPU: NVIDIA GeForce RTX 4070
- Main BIOS chip size: 32MB
- VBIOS chip size: 16MB
What I Have Tried So Far:- I
11-04-2025, 05:14 AM -
by brav1ezHello everyone,
I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
I’ve tried:
- CMOS reset
- Removing the SSD/HDD
- Reseating RAM (removing each stick individually stops boot completely)
- Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
With...09-07-2025, 10:47 AM -
by chaos-theoryI have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and... - Loading...
