Cannot attach pics anymore , how do I do it?
How do u attach pictures to post
Tags: None
Re: How do u attach pictures to post
Use this link
https://www.badcaps.net/forum/showthread.php?t=39740Comment
Upload u r pics to some site then click a icon on yellow picture it ask for link then paste ur pic uploded link thats allComment
attachments are temporarily removed and disabled... will be back in a couple days. in the mean time use an image host like http://imgur.com/Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by bryanXHi guys!
Firstly, I will apologize if my topic is in the wrong section, please move it if necessary.
I want to repair one treadmill from the brand Horizon the model is Omega II. Practically, the motor power control board has suffered one damage.One mosfet has blown and I suppose by doing that, the short circuit has damaged a couple of diodes, one zener diode and two transistors. I hope that is all. I will find out when I will put them all back on board. I have dismantled and cleaned the rotor of the DC motor, tested it, and it seems to be working properly. I suppose it was water...5 Photos -
by bohabohaHi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
anyhow i couldn't t read anything else
the backlight is on strong and the screen does not get dark or very dark but no pictures
the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
by valvashonThe 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it... - Loading...
