I need some help to fix this tv, when you turn it on the backlight comes on for a split second then goes off and stays off. When I shine a light you can see the picture and the sound works too. I fixed 2 tvs before with help from this forum but they were both to do with the psu and involved soldering a couple new caps in. Seems like this is the inverter board? but im not sure where it is. ive taken some pics and im wondering if its that small board under the psu?
Hitachi 32HXC01U A backlight problem
Re: Hitachi 32HXC01U A backlight problem
not sure if you have read any of these threads but some have some voltage test points so maybe worth taking some and going from there
https://www.badcaps.net/forum/search...archid=5804621 -
Possibly and open Led or Psu fault. Check out what Vince linked.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
by wolf1976hi
i have the above tv and the display starts distorts the display at only in applications like you tube
after and on the didital channels
now without connect the antenna only the image of itsselfs tv i have the image i have in attach
i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?... -
by DobrowolHi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?04-28-2025, 04:30 PM
by ononoshello everyone!
As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
So i decided to try to... -
by fanaticgameshello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
by Phil289Hi
Would be greatful for some help regarding this problem.
Tv turns on , Hitachi logo appears with no problems , then depending on how lucky i am i either get a fully working tv for around 5/10 seconds and then the left side of the screen dims down (not dark just dimmer than the right) or sometimes it will just go past the boot logo and go straight to the dimmed left hand side straight away.
Sometimes turning the tv off and then on again will make it fully bright again but it will then dim on the left shortly after.
It is a vestel setup with a 17ips71 (190814R4)... - Loading...
