Samsung UE40F6500 No video, has audio
  • ilzi92
    • Sep 2014
    • 14
    • Österreich
    Hello
    I have some problems with the following Samsung TV:
    i've check the voltages from the PSU and there are correctly
    12. BLU ON/OFF - 4.95V but no backlight, so i mean the psu have an issue
    and i dont know for what the following is:
    3. OD_ON/OFF --> 0V
    can somebody help me
    cu and best regards.......
  • CapLeaker
    Leaking Member
    • 8352
    Re: Samsung UE40F6500 No video, has audio
    probably a bad LED. Can we see a clear straight shot picture from your PSU?
      Power supply/LED driver board P/N BN44-??????
      • ilzi92
        • Sep 2014
        • 14
        • Österreich
        • ilzi92
          • Sep 2014
          • 14
          • Österreich
          So i checked the backlight LED's and some are bad....
          but i dont can buy the LED Interface (BN96-25336A)
          have anyone a source to buy the LED's individually
          thankssss
          • ilzi92
            • Sep 2014
            • 14
            • Österreich
            Picture from my LED Interface...
            so when i change the broken LED with (used) LED's (from other Samsung TV),
            then i think the other (good) LED's would broken also from time to time?
            • samson7point1@yahoo.com
              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
              by samson7point1@yahoo.com
              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
              The player processes the audio signal using two different reference frequencies. The "R"...
              04-30-2024, 11:22 AM
            • alro7779
              Samsung UN55MU6103F video problem; has colored stripes on the display
              by alro7779
              Hello, everyone!
              A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
              09-27-2025, 11:29 PM
            • SolarFlare
              Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
              by SolarFlare
              My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
              The TCON board has the following Chips -
              Samsung VTU63A0
              RT6939 - 2nos.
              and all these chips are getting real hot within a minute, I dont know if this is normal....
              06-26-2022, 08:58 AM
            • frannyjunk
              Samsung UN32M4500 has audio but no video
              by frannyjunk
              Hi, I have a Samsung UN32M4500 that turns on, has audio but no video. No Samsung splash screen when turning on, but I can see the backlights (screen is just this dark gray color). The TV only has one board, which I replaced from one I purchased from directtvparts on eBay. But still the problem persists. Is my LCD bad?
              06-05-2021, 08:34 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
