Can these horizontal lines be caused by a bad T-Con on LG 47LN5400?
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I know that lines on screen are usually caused by bad panel; however this one is a little different. Lines start on the left panel, but slowly fade as they go right (see attached picture).
    When the TV is on and I start to slowly release the left ribbon cable latch, on certain occurrences I can get the picture to show perfectly with no discolorations, lines of shadows. But that is only when the latch is released in specific position. I get the same results when releasing latch on the T-Con and on the driver board itself. Applying pressure to tab bonds had no effect. I re-seated and cleaned all cables and connections.
    Could this be a T-Con issue after all?
    Thanks,
    Happy New Year
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Can these horizontal lines be caused by a bad T-Con on LG 47LN5400?
    Possibly there has been a few threads on this, the motherboards were at fault.
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      Well, I got another T-Con board and same problem, so I am guessing that it is the driver board and/or panel issues. Oh well.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Did you even read what I put ? I said motherboard which has the Hdmi inputs etc has been known to cause this.
        • Pioneerx01
          • Apr 2015
          • 241
          • US
          The issue is across all inputs. If you look at the picture of the issue, it is concentrated to one half of the panel, other side is OK. Usually when mains are defective they cause issues cross screen.
          You have mentioned other threads, what are the URL's?
          • freakaftr8
            • Oct 2012
            • 3743
            That looks like panel failure to me
            • jjanssen7
              • Nov 2012
              • 252
              can be repaired with scotch tape covering one side of the connections to the tconn. try tape covering the last 8-9 connections on the ribbon that connects into left ribbon cable latch you mention.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8352
                What happens when you bring the OSD menu up?
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  Please elaborate in as much detail as you can! I have run into this fault a few times,as a matter of fact the 55" I have hanging in the bedroom has it(can't sell it this way.might as well use it).
                  Proud owner of dozens of broken TV's and many,many,many boards.
                  Our website and passion:http://hollenhundshepherds.com/
                  • jjanssen7
                    • Nov 2012
                    • 252
                    Power off the TV.
                    Remove left side ribbon (or sometimes the right, experience helps when selecting which side). You already discovered the left side was a problem so the below assumes we're working on the left ribbon.
                    Place scotch tape covering some (start with 8 to 10) of the connectors, always starting near the edge (in other words, when trying this, the left side or the right side of the (left) ribbon will always have connectors covered by tape).
                    Insert ribbon back into the tconn carefully and test.
                    Do not leave the TV on long. Sometimes this can "fry" a tconn.
                    Power off TV.
                    If that doesn't work try covering some on the right side of the left ribbon.
                    If the picture is worse, etc you will have to put on a "thinner" piece of tape, cover maybe only 5... it's a bit of an acquired talent... covering the least number of the connectors to get a good picture but enough to stabilize the image.
                    I have repaired 5+ of these LG panels doing this.
                    • braxton
                      • Nov 2009
                      • 146
                      Power off the TV.
                      Power off TV.
                      Does this imply that not all of the connections from the ribbon are required to generate the image?? Or are you taping the back side of the connectors to make the cable fit more tightly?
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        excellent! Thank you for that information,will try that on this 55" asap.
                        • jjanssen7
                          • Nov 2012
                          • 252
                          Not all the connections are required to generate the image. The tape trick is a deliberate attempt to cover some of the electrical connections.
                          • dogdad
                            • Nov 2015
                            • 35
                            • usa
                            Almost the exact symptoms on a Sony Bravia. Turned out to be one of the TAB strips (I think that's what they're called) that wasn't making good contact with the panel edge. Found it by gently poking along the TAB strips til I found the one that cleared up the problem. I then put some weather-strip material over it to keep it pushed down and making contact.
                            BTW, I found that you CAN fry a T-conn board by unplugging some of the ribbon connectors. Wanna guess how I know?
                            • braxton
                              • Nov 2009
                              • 146
                              Any luck?
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • Ihandyrepair
                                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                by Ihandyrepair
                                Hi guys
                                I just started fixing 4k TV few months ago. so I am still learning a lot
                                I got this tv from friend complaint is ghosting or horizontal lines on image.
                                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                then it started to show the ghosting white image.
                                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                it has 3 thin small boards at the bottom of the...
                                12-05-2022, 04:18 PM
                              • ggil44
                                Sony XBR-65X750D Horizontal lines bottom of screen
                                by ggil44
                                Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                05-30-2023, 07:51 PM
                              • kca
                                by kca
                                Hello all ~
                                08-31-2025, 06:38 AM
                              • rstrube
                                ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                                by rstrube
                                Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                                Hi Everyone,
                                I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                                Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                                11-23-2025, 01:37 PM
