hi all, ive been looking around here and think this is the place to be for the vast amounts of knowledge kindly available.
i own a panasonic plasma tx p50st31b bought at least four years ago with a date stamp of 03/2011 inside the rear panel.
it has been very reliable uptill now :-(
im currently getting 7 red flashes off the sos. i disconnected the two connectors for the sc panel and i was presented with 8 red flashes, i then re attached the two connectors to receive 7 flashes once more.
the tv died during using kodi via pc hdmi etc. ive allways used the side port for some reason. only thing slightly different was when i moved my computer the power lead to my pc became loose and reset my pc, obviously picture went from that source. i also inadvertantly cut the power to the tv without pressing standby if that could be anything to do with it.
all was well for an hour then a bang was heard and it went off. it was dark and dont remember doing it but i have also noticed an impact type crack on my lower rh side of the panel, directly behind the power connector fot the ac board. i moved it onto the table this morning upright and im always usually very careful with it.
can components breaking cause the screen to break or is this likely human error? its hard to say if the picture will be ok with the crack but when i disconnected the sc board i did think i noticed a small 2" square of light around where the crack impact area is.
im kean to try to repair it as its been a great telly with a cracking picture. but if the panel is likely to be defective then its just more £££'s
any suggestions kindly received
rich
rich
