Hitachi 42pd580dta
  • wozzie
    • Dec 2014
    • 21
    Hitachi 42pd580dta
    Need help i accidentally locked the front control panel and i dont have a remote to unlock it . Can anyone please help .
    Thanks regards John
  • wozzie
    • Dec 2014
    • 21
    Re: Hitachi 42pd580dta
    Fix it with a harmony remote . All good now.
    • dfear
      hitachi 75hl16t64u - not responding to remote control
      by dfear
      I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
      It came in for a power issue which I have finally resolved by replacing the power supply.
      The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
      Anyone have a clue how to fix TV?
      FYI: I have checked the remote work s by pointing it at my camera on my phone....
      09-02-2024, 12:15 PM
    • cstout
      DeLonghi AC Remote only accepts 3V
      by cstout
      Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
      The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
      I can't find any schematics...
      06-03-2024, 03:53 PM
    • Mc_Millian
      Toshiba 50lf711u20 fire tv remote not pairing
      by Mc_Millian
      I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
      The Tv model number is: 50lf711u20 Rev B.
      I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
      I've tried 3 different remotes which should be fully compatible with this TV.
      Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
      The power button, along with the volume,back,select, and directional...
      04-07-2022, 12:15 PM
    • tfatt
      Hitachi Flora Se210 Bios Locked x3
      by tfatt
      Hi There,
      Anyone able to help me to look and remove the bios password on this Hitachi Flora Se210 model, (bios password locked).
      Attahced the dump file and screenshots of the bios model....
      10-22-2021, 03:22 AM
    • edugimeno
      HiSense 55A7500F won't obbey to remote after power on
      by edugimeno
      Hi! I have this TV set that does the following:
      1) I press the red power button on the remote
      2) The TV turns on normally
      3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
      4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
      Then after it's off, it would again accept the TURN ON from the remote and same again
      BUT:
      -The remote does show the correct IR beam while observed thru a phone camera
      -The TV works fine while using the MiRemote...
      03-14-2023, 11:22 AM
