ps50c77hdx/xec
    Re: ps50c77hdx/xec
    You need to GND that pin though 100 Ohms resistor.
    I use resistor in case you GND the wrong pin directly to GND.
    • flocko
      • Nov 2012
      • 1121
      • uk
      #42
      Re: ps50c77hdx/xec
      just put PSon to ground no resistor needed, relay should energize and give you small voltages. for VSon use a resistor (470-1k) to 5v stby this should bring high volts(VS) to life, all connections need to be removed from board apart from the mains in in order to do this stand alone power board test
      • lamouche1
        • Feb 2011
        • 12
        Re: ps50c77hdx/xec
        now there's a 50 ohms resistor to ps_on and still no go. 1 got 1.041V on the cold side of the optocoupler. at the pnp transistor between ICQ805 15v and the opto it got 20V on the Emittor and the Base via a resistor then another resistor going to the opto. i have nothing on The Collector/ICQ805 input at 0V. what should I check next?? thanks
        • lamouche1
          • Feb 2011
          • 12
          Re: ps50c77hdx/xec
          ok i found it the culprit was the 7815 regulator. testing good outside of the circuit but acting weirdly in circuit.. the set back in working order thanks guys for the help
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Yanleb
            Schematic or datasheet for Plasma TV buffer chip
            by Yanleb
            I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
            So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
            Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
            05-18-2022, 01:36 PM
          • hoarderteks_kyriakos
            Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
            by hoarderteks_kyriakos
            Hello.
            Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
            Here is what happened:
            At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
            10-08-2025, 07:33 AM
          • legg
            LG 42PC3 buffer output doesn't follow YSUS
            by legg
            LG42PC3D -UD originally with green lamp but no display or audio.
            Owner says was working, then went 'pop'.
            All 5V caps bulging. replaced.
            All PSU output voltages within spec but -Vy is low on YSUS.
            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
            eventually shorts DG. Replaced all 3 - -Vy now OK.
            Y scan buffer test point does not follow YSUS output below -50V
            Note: This unit seems to expect YSUS output to park at -Vy in between
            drive signal pattern periods. A replacement drive signal board confirms this....
            11-18-2021, 11:49 AM
