Vestel 17mb61-2 Firmware Problem
  • ducky29
    • Dec 2015
    • 370
    • Europe
    Hello! I am trying to fix a F&U Tv ( Vestel boards).
    Led is flashing and the screen dosen't turn on.
    PSU 17pw25-3
    MainBoard 17mb61-2
    I checked the diodes and none of em is shorted ,also checked capacitors.
    Everything looks fine.Just to make sure I replaced the PSU but it didn't fix the problem.
    I replaced the inverter but It still didn't fix the problem.Also unplugged the buttons panel.
    So I thought the last thing to do is to update the firmware.I found the firwmare then I put it into a flash drive and I plugged it in.
    I tried pressing OK button or P+ button but none of em worked.
    Is there any way else I can update the firmware or maybe another procedure?
    Thank you!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vestel 17mb61-2 Firmware Problem
    Firstly was the replacement Psu the exact match for this Tv and I dont mean the 17pw25 part number I mean every little part number on the Psu ?
    • ducky29
      • Dec 2015
      • 370
      • Europe
      Yes it was exactly the same part.
      I just left the tv on for about an hour and the led stopped blinking.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok, one thing is if you put the incorrect Psu (must be for that model and board!) in it will cause your fault. What firmware you have also got the Mboot folder ?
        • ducky29
          • Dec 2015
          • 370
          • Europe
          I only got the bin file(17mb61-2.BIN).I also got 17mb62 firmware but I don't think it can help me.(mboot.bin mb62_en.bin and usb_auto_update_mb62.txt)
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            You have a DMM ?
            • iuliantv
              • Aug 2009
              • 35
              • Romania
              no need mboot.bin is enough usb_auto_update.... and ...mb61.bin ...., put these two files directly to USB stick without archive or folders, disconnect the TV from the mains supply, insert the USB stick, press the OK button and holding the remote control, the TV is connected to the mains, the OK button is released when the front LED starts flashing rapidly, expect about 1-2 minutes and the TV will start one of the first installation, the display is important to tell the type of TV you, success
              https://www.xfile.ro/download/4e0a59...b0a519340.html
              • ducky29
                • Dec 2015
                • 370
                • Europe
                You have a DMM ?
                Yes I do.
                Ok thanks, I will try tomorrow when I get back to work.
                • Bazilwrc164
                  Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                  by Bazilwrc164
                  I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                  The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                  I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                  If anyone can provide:
                  • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                  • Or a compatible EEPROM dump
                  Today, 12:15 PM
                • Unimatrix
                  (Vestel) Telefunken XF43G511 - Thermal problem
                  by Unimatrix
                  I came across this forum because I need some advice about my Telefunken XF43G511 TV. It is originally a Vestel device. For some time now I have had the problem that the TV gets a black screen when the electronics are heated up. The backlight is still there and the sound still works. It's just the screen itself that goes off. When I switch off the TV and it cools down, the TV works again after a while. Could you please give me some advice on what could be causing this problem? I have also attached some photos of the electronics.
                  Kind regards
                  Thomas...
                  11-19-2023, 08:39 AM
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • cheeky2
                  Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                  by cheeky2
                  I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                  Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                  The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                  Details:...
                  08-17-2023, 04:34 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
