BUSH 40" led40127fhdcntd Wifi Dongle Detected
  • speedypro
    • Feb 2013
    • 561
    Im working on a tv that keeps saying "Wifi dongle detected". Nothing is attached. Any ideas? Is there a BIOS dump available to just re-flash this?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: BUSH 40" led40127fhdcntd Wifi Dongle Detected
    Look for 17MB95M core update on google. Do you know how to update the firmware on these ?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Before you try firmware, desolder the USB port on the mainboard and see if it still does it.
      A working TV? How boring!
      • speedypro
        • Feb 2013
        • 561
        I assume the way i remove ic off laptops and flash?
        Ok ill try this. Thanks
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          No easier than that and you cant do it that way you need the Mboot folders but as it still boot doing a core update might work. Find the core update, put the folder on a fat32 formatted Usb, put tv in standby plug in Usb to port, power on hold "Ok" on the remote. If done correctly the Led will flash really fast for about 2mins then the Tv will boot up.
          • howardc64
            M557-G0 no WiFi/Bt no WIFIVendor file?
            by howardc64
            Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
            • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
            • Service Menu shows many Bt/Wifi info missing
            • Vizio app shows no WIFIVendor file
            Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
            • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
            10-15-2024, 01:12 PM
          • ugamazing
            820-00850 & 820-01949, No WiFi *In Recovery*
            by ugamazing
            I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
            1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
            2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
            01-25-2023, 05:39 PM
          • AlexVG
            Replacing the WiFi module on a vacuum cleaner iROBOT i7
            by AlexVG
            I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
            I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
            (This board does not respond, only the LEDs light up in a circle.
            The liquid damage is catastrophic and restoration is impractical).
            (I bought this board to get the WiFi module and camera).
            The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
            If...
            10-22-2024, 07:20 AM
          • EvazX
            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
            by EvazX
            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
            However, after some time, the replacement motherboard...
            08-25-2025, 06:09 PM
            Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) Studio Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H boardview and Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H schematic. Our users have donated over 1 million documents...
            09-07-2024, 04:10 AM
