Hello everyone....I need the software for an Tv "Princeton" with the chassis from the title. My Panel is VES275WNVXN01. Thak you for help
Vestel 17MB55 - update software
by eclectricHi, I'm hoping someone can help me with this issue before I give up on this TV.
In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by sigmeyerI have a customer complaining that tv has a software issue .. He tried to update with some other software but first he had issue of no picture , then after another update he had no sound but had picture. So its pretty clear its a software problem.
So im trying to help him out and find him the update software
TV in question:
Grundig new york 46 3d WEB((GBJ 91 - 46))
Panel - LTA460HQ08 // 056D46-SS10
I have found a softwareupdate_gbj7246.zip file online , but obviously is not the same , it is for the same panel but not the same model ..i cant even download it... -
by cheeky2Unfortunately Toshiba took all there TV firmware updates down a while back and I would like to put the latest core update for this main board on this Toshiba TV set as I am having a few issues accessing the Smart TV functions. Does anyone have access to the original firmware update for this UK model please?
Thanks in advance and Happy New Year
by StephenComputer boots and gets the software update. No visible water damage. All connections tested on another logic board and they all work. The logic board only gives this error when booting normally. Boots fine in safe mode. None the less still looking for visual damage and nothing shows damaged on the board. Board has everything disconnected except the USB C and battery so it can boot normally. Plugged up to external monitor. Boot into safe mode and I'm now trying to install Combo update and see if that works, if not any suggestions? I also checked the Wiki Critical Software update page and followed...
- Loading...
