Hello everyone....I need the software for an Tv "Princeton" with the chassis from the title. My Panel is VES275WNVXN01. Thak you for help
Vestel 17MB55 - update software
by eclectricHi, I'm hoping someone can help me with this issue before I give up on this TV.
In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes... -
This machine came in with a no power complaint after a liquid spill. The only damage I found was on the two USB-C boards, so I replaced those, and the machine charges and fires up. However, if the internal LCD is connected to the logic board, when it boots, I will get a critical update failed warning and the only options are to shut down or try again - it's a loop. I am able to start up fine in safe boot. If I disconnect the internal LCD, I am able to boot normally to the OS. The customer doesn't want to invest any more money beyond what I already charged. Unfortunately, based on what I...11-21-2025, 01:12 PM
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by sigmeyerI have a customer complaining that tv has a software issue .. He tried to update with some other software but first he had issue of no picture , then after another update he had no sound but had picture. So its pretty clear its a software problem.
So im trying to help him out and find him the update software
TV in question:
Grundig new york 46 3d WEB((GBJ 91 - 46))
Panel - LTA460HQ08 // 056D46-SS10
I have found a softwareupdate_gbj7246.zip file online , but obviously is not the same , it is for the same panel but not the same model ..i cant even download it... -
by cheeky2Unfortunately Toshiba took all there TV firmware updates down a while back and I would like to put the latest core update for this main board on this Toshiba TV set as I am having a few issues accessing the Smart TV functions. Does anyone have access to the original firmware update for this UK model please?
Thanks in advance and Happy New Year
- Loading...
