A1706 Critical Software update. Not Touchbar etc.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Computer boots and gets the software update. No visible water damage. All connections tested on another logic board and they all work. The logic board only gives this error when booting normally. Boots fine in safe mode. None the less still looking for visual damage and nothing shows damaged on the board. Board has everything disconnected except the USB C and battery so it can boot normally. Plugged up to external monitor. Boot into safe mode and I'm now trying to install Combo update and see if that works, if not any suggestions? I also checked the Wiki Critical Software update page and followed all steps to no avail. Any suggestions would be appreciated.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Re: A1706 Critical Software update. Not Touchbar etc.
    Combo update didn’t solve the issue. Still having issues
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Bump
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        Bumping this again. Logic board boots into safe mode etc. Boots externally into safe mode with no attachments. But when booting normally it has the software update requirement with nothing attached. Logic board is operating normally minus this issue so trying to trace points where we should check. Thanks again
        sigpic
        • jimanez11
          • Jan 2015
          • 93
          Have no idea if this actually works or not, but have heard that if you manually set the system time (through terminal from recovery partition) to 1/1/2016 you may be able to get past this. Again, haven't tried it but resetting the system time is too easy not to at least try it? Let me know if it works?
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 667
            Will test this Monday!
            sigpic
            • iMuhtaseb
              A1706 2017 critical update
              by iMuhtaseb
              this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
              we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
              One weird symptom is it takes too long to power on and show the Apple logo for some reason..
              I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
              08-13-2024, 08:41 AM
            • eclectric
              Sony Bravia KDL-70W850B T-CON board / software update issue
              by eclectric
              Hi, I'm hoping someone can help me with this issue before I give up on this TV.
              In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
              Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
              I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
              05-23-2022, 01:25 AM
            • Instafixx
              Macbook A1706 820-00293
              by Instafixx
              Namaste.
              We have a Macbook A1706 (820-00239). The laptop was bought back from a customer. The touchbar was broken ( No Image) but touch used to work.
              One day it had a "Critical Software Update Error" issue.
              So we tried a lot of things.
              Re-installed the Software.
              Unplugged the Touchbar Flex etc.
              It then got back to working but the touchbar now became totally unresponsive. (No Image. No touch).
              We ordered a new touchbars but none of them worked. We thought they maybe they were faulty. We tried installing...
              02-09-2023, 11:20 AM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • sigmeyer
              Need a firmware update software for grundig gbj-9146
              by sigmeyer
              I have a customer complaining that tv has a software issue .. He tried to update with some other software but first he had issue of no picture , then after another update he had no sound but had picture. So its pretty clear its a software problem.
              So im trying to help him out and find him the update software
              TV in question:
              Grundig new york 46 3d WEB((GBJ 91 - 46))
              Panel - LTA460HQ08 // 056D46-SS10
              I have found a softwareupdate_gbj7246.zip file online , but obviously is not the same , it is for the same panel but not the same model ..i cant even download it...
              03-10-2021, 04:16 PM
