Sanyo DP26649 Freezing, Restarting
  • obScene
    • Dec 2015
    • 5
    • US
    Complete noob to working on TVs. What I'd like to do here is simply figure out what board to replace as I don't think I'm up for replacing individual components. My son has a Sanyo DP26649 I bought used and I liked it because it has a lot of different inputs for game consoles, PC, etc.
    Randomly, the TV screen will glitch for a brief second as well as repeat the last bit of audio that was playing. It just lasts for a second, then the TV will "restart." It never loses power, but simply goes black and a few seconds later will return to normal. On a rarer occasion the TV screen will stay black and not react to the power button being pressed, meaning it has to be unplugged and turned back on to resume use.
    This started as a rare occurrence but now it can happen pretty regularly every 10 minutes of use. This happens independent of what inputs are being used (HDMI, Component).
    As a sidenote I notice my son had the extra yellow video cable from his Xbox 360 (not used for component video) wrongly plugged into an audio output. No idea if that could cause damage or not.
    I'd love to figure out if I need to just replace the main board or something else so that I could get it ordered and here before Christmas. Any help / directions would be greatly appreciated.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: Sanyo DP26649 Freezing, Restarting
    Question now is:
    Is the mainboard acting funny because of bad capacitors on the power supply, or is it the main board itself.
    Since there are no pictures to go with it, no testing or voltage readings have been provided, there isn't much we can do here...
    • japlytic
      • Oct 2005
      • 2086
      Have you tried checking the outputs of the linear regulators (1117 etc) as they warm up?
      On the forums, I have read that a number problems in TVs were a result of linear voltage regulators failing.
      In an AWA MHDV2211 LCD TV/DVD combo, one of the 1117 voltage regulators dropped out as it warmed up, causing the video processor to crash - a replacement fixed this problem.
      So have you tried carefully heating the linear regulators?
      • obScene
        • Dec 2015
        • 5
        • US
        I think you guys missed the "complete noob" part of my post. I don't know what to test for voltage or what a linear regulator is, but I'll be glad to pop this thing open and post some pictures or follow any other directions.
        • obScene
          • Dec 2015
          • 5
          • US
          Opened her up, nothing obvious to me as far as bulging / melting capacitors and that's pretty much the extent of what I know to look for.
          I have a multimeter that I don't really know how to use or what to check and what to check for, but if anyone has pateience to tell me I'll gladly do it.
          I have noticed that every single listing for that board reports it to be out of stock so I'm suddently not optimistic about fixing this.
          Sorry for low quality pics, also in the midst of getting my camera repaired to used a tablet.
          • obScene
            • Dec 2015
            • 5
            • US
            Nothing?
            • altanok
              Samsung UE55h6270ss restarting/freezing/turning off
              by altanok
              I have this tv to repair. Tv start and sometimes i can watch for 30sec to a 1 minĂște a then it restarts or freeze and then turn off or grey picture and then restarts and standby light blinks 4 times. The sound on the tv is not working as well and sometimes big sound icon will show Up for a while (dont know if it could relate ). A send motherboard to some guy to replace software or eeprom, something like that and it did not fix the issue. The guy seemd scatchy and it took him 2 or 3 months to do it. After the mother board came i meeded to set up the tv with his instructions but i did not find...
              03-10-2024, 09:58 AM
            • yuii
              ThinkPad W530 - faulty CPU regulators?
              by yuii
              Hello
              I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
              Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
              The latter is completely dead and has the same 2-second power blink, nevermind...
              11-01-2023, 02:59 AM
            • CornholioGSM
              Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
              by CornholioGSM
              I have here one interesting problem.
              Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
              I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
              Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
              06-25-2024, 12:27 PM
            • FShahid
              Dell Inspiron 7520 (Intel/AMD) LA-8241P Freezing Issue
              by FShahid
              Hi I have Dell 7520 which has i7-3632QM as well as AMD 7730M Discrete Switchable GPU.
              This is BACO Switchable meaning the AMD GPU can only "render" and cannot work as alone as it depends on iGPU for output.
              Attached is the datasheet for LA-8241P which shares common with Inspiron 5520 and Vostro 3560. Link to Schematics: https://cdn.badcaps-static.com/pdfs/...a856347d78.pdf
              The laptop has worked flawlessly for last 9 years, with CPU temps never exceeding 90*C and GPU barely reaching 80*C on gaming/full load.
              Since...
              04-26-2022, 04:41 PM
            • seweryn
              Dell 2007FPb with 4 buck step-down regulators
              by seweryn
              I have monitor Dell 2007FPb. It was working good. Some day it was shut off and stay dead.
              I checked some voltages on the boards. I read this thread:
              https://www.badcaps.net/forum/showthread.php?p=335335
              and very usefull budm posts ( thanks buddy, it was great work ... ).
              My damage was typical: 3A fuse burned and ZD701 diode was shorten.
              So my board is in few points different than other described in citing thread. On my board are 4 buck converter regulators. Apart regulators 3.3V (Q6), 5V (Q14), 12V (Q9), is ther fourth, build on MOSFET Q2. Two TL1451 has together...
              04-08-2022, 11:43 AM
