Seiki SE50FY10 sound no picture, NEW main board
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Seiki SE50FY10 sound no picture, NEW main board
    Have you read post #9 and what voltage do you have?
    • heavymachines
      • Mar 2011
      • 1028
      Read this entire thread and so you have 123 volts output? to leds? if yes then you need to replace the leds. Seiki in uber cheap made sets. 100 to 200 new. However if you replace those leds with higher quality it should last longer.
      • web5
        • Apr 2017
        • 21
        • US
        Ok, i think i will call someone to do the testing.
        So TV can be repaired ?
        Also TV worked fine for 3 years, and problem occurred after i set a
        digital watt meter - can be this a reason that cause the problem ?
        Thanks.
        • web5
          • Apr 2017
          • 21
          • US
          Also TV worked OK, and after i turned off, next powering On was without Backlight.
          Can be that is something wrong with electronics since it did not blackout during wathing TV ?
          • web5
            • Apr 2017
            • 21
            • US
            Just mesured CON11 DVC = 124.5v
            Is it OK ? Or that is a problem ?
            • via3D
              • Nov 2017
              I have a Seiki SE50FY10.
              I am new to the board.
              Its been 20yrs since I have used electronic troubleshooting skills, (AS degree).
              ... so I am not a qualified tech by any means, but an avid DIY. LOL
              Posting here due to being a noob on forum (thus cant start new thread)...
              ISSUE CURRENT: Blue light comes on, no sound, no picture.
              Background:
              ~TV 2 to 2.5 yrs old.
              At 1yrs old... had pic but no sound... then sound and no pic, then both went out. Was a bad solder joint for the power connector. easy enough.
              Now, I assume the flashlight trick is shine a light at the tv screen face???
              if so, nothing, just black.
              I do get AC voltage at power connector that was bad last time and no evidence of any other bad solder or burnt parts.
              Ideas where I can start... I was going to order a power main board
              but it sounds like fun to perhaps troubleshoot some if the team here can guide me.
              Seems LED's are quite a problem in these, but symptom is different since I have no pic from flashlight test?????
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
