Panasonic DP46848
  • dbier63
    • Aug 2015
    • 157
    • usa
    Panasonic DP46848
    I have a Panasonic DP46848 that I've been troubleshooting. It originally had a tab bond failure. I applied heat to the tabs and when I powered up the horizontal screen issue was gone but now I have a thin black vertical line (very thin) a third of the way over on the left side. I think I may have damaged the bond or the little chip in the bond with the heat. Am I correct in thinking that I now have a ruined panel?
  • awyatt2
    • Feb 2012
    • 407
    • america
    Re: Panasonic DP46848
    if you damaged the bond or the chip then you ruined it. they use a conductive type of glue to affix them I think.
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
      Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
      The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
      Securing a good thermal interface between...
      10-07-2024, 04:35 AM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      I happened several times, in the search for help from the web, to consult this very interesting forum.
      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
      Having said that I come to the gist of my post on the forum as the title suggests.
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
    • aa10aa10
      Panasonic Toughbook CF-33 mk1 BIOS repair
      by aa10aa10
      Good day,
      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
      01-21-2025, 06:13 AM
