Resistor Help
    Resistor Help
    I want a 5.6 ohm, 1/3 Watt 0603 size resistor. I need it to replace Panasonic D0GF5R6JA047 M 5.6 OHM,J, 1/3W. This part blows due to arcing on the Panasonic Plasma TV. I found a place that sells the OEM part in the US, but the fuckers want $93US to ship to Canada. Not paying that for a resistor. If anyone knows where I can find a replacement part, please share, or can I use a 1/4W resistor. I found 1/4w, just no 1/3W
    See part here:
    http://www.digikey.com/product-detai...ZCT-ND/5036348
    Re: Resistor Help
    have you measured that part? what about this which is at least close to 1/3w measures 2mm x 1.25mm
    SUSUMU RP2012T-5R6-F Surface Mount Chip Resistor, Thin Film, RP Series, 5.6 ohm, 330 mW, ± 1%, 0805 [2012 Metric]
    http://canada.newark.com/susumu/rp20...805/dp/28K1533
      Re: Resistor Help
      I found this bulletin. Presumably Panasonic knows about this problem and needs a resistor that can dissipate more heat? If yes, why not just bodge in a 1/2 W through hole resistor onto those two pads and use some high temperature silicone glue to secure it in place?
      http://www.digikey.ca/product-detail...6/5.6H-ND/2240
      --- begin sig file ---
      --- end sig file ---
        Re: Resistor Help
        @tech2014, it is not good form to ask the same question in more than place.
        https://www.badcaps.net/forum/showthread.php?t=50891
