LG 60pk550 turning on and off
  • Logen1
    • Mar 2017
    • 32
    Re: LG 60pk550 turning on and off
    Ok here is my problem....the set will not light up at all, initially it was dim and I could make out a faint image, after testing the lower buffer I think it fried it because now there is no image at all. When I disconnect the Y Sus ribbon cable and detach the buffers but leave power going the the X drivers through the YSus and turn the set on I can see vertical lines on screen as well as static. But I turned it off right away as not to cause any more damage.
    I was curious if it is possible to use the power board/ YSus, Y Buffers/ Z Sus from these two sets? Would they be interchangeable? All the connections are the same and the board components appear to be identical. The only things different are the logic board and the 3D driver board on the one set. I am trying to take the working parts from the 60PX950 and put them in the 60PK550. I believe the YSus has Failed and I was going to swap the YSus and buffers. Thanks for your time once again.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
