Vizio E320VL powers on but not past splash screen
  • jspoe13
    • Dec 2015
    I have a Vizio E320VL that just stopped working. When I power it up the Vizio logo on the frame turns from Amber to White and the Vizio logo splash screen comes up for a second and then goes to a dark blue screen. No video comes up and menu options won’t display. I also can’t power off the unit unless I unplug it but it will turn itself off after about 1-2 minutes.
    I’ve checked all the regulators on the Main Board and they check out as normal. I’ve read a lot of posts on here talking about the U33 regulator going bad but this unit doesn’t have a U33 regulator. I’ve also read a lot about the U18 EEPROM being a problem.
    Do these symptoms sound like an EEPROM issue? If so, is there a way to test the EEPROM?
    Any help would be much appreciated.
  • jspoe13
    • Dec 2015
    Re: Vizio E320VL powers on but not past splash screen
    This video fixed the problem. I would have never checked the IR board.
    https://www.youtube.com/watch?v=sDwZQIZB1nU
    • csmith
      Vizio D50u-D1 Powers up no picture
      by csmith
      I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
      Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
      supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
      issue. Set will power up with remote but not power off....
      07-11-2025, 11:52 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • JaquesPratt
      Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
      by JaquesPratt
      I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
      This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
      07-16-2024, 01:04 AM
    • shelby5041
      Vizio E320VL powers on but no backlight
      by shelby5041
      hi
      i beleive issue is bad inverter section on the ps
      i power tv on and the vizio logo goes from orange to white and i can see startup the vizio logo show on the tv screen (no backlight)
      i have 12v and 5v and 3v blon at the ps
      after about 2 min of tv not connected to vidoe source it goes to standby and vizo goes to orange i believe this is notmal
      doing a brief search brings up a repair kit for the ps/inverter obard on shop jimmy so i assume this is a common issue
      here are pics of the stock board and repair...
      08-03-2020, 03:10 PM
    • npolite
      Vizio E320-A1 Powers on But No Display
      by npolite
      Hi All,
      I have a Vizio E320-A1 which lost sound and picture. The power LED comes on and stays on but nothing else works. I am not able to power it off unless I unplug it.
      Here are the voltages when the power is on
      1 - 5.25
      2 - 5.25
      3 - 0
      4 - 4.8
      5 - 25
      6 - 25
      7 - 0
      8 - 0
      9 - 0
      10 - 12
      11 - 12
      12 - .9
      13 - .5
      Can someone let me know if the issue is with the mainboard?
      Thanks...
      04-19-2024, 11:33 AM
