Samsung PN59D530 Won't Turn On
  • AFajitas
    • 183
    Got this Samsung PN59D530 59in plasma from a guy that said he had two of them that both got fried after a lightning storm. Both fuses on power supply check out okay. On the header that goes from power supply to main board, I am getting 5.3v for PS_ON and 2.7v for Standby, but no readings from any of the other pins. When I unplug the cable from the motherboard standby then reads 3.8v instead of 2.7.. I tried to jump standby and ps_on and still got no readings from the other rails, but I think maybe I am not jumping it right.
    How can I determine if it's the mainboard? What's the proper way to force this tv on without a mainboard? See pics.
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung PN59D530 Won't Turn On
    To jump the power supply on the PS-ON signal needs to go low.
    So you'll need to connect PS-ON to GND
    And in some models VS-ON to 5vSTBY
    I suspect you have a faulty mainboard as when you press the power on button the ps-on signal should much lower than 2.7v
    • AFajitas
      • 183
      I think it is a bad main as well. I got a good deal on a replacement and will keep you guys updated.
      • husky601
        • Apr 2015
        • 36
        So did you swap the main board?
        • PNI E.
          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
          by PNI E.
          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
          03-17-2025, 04:23 AM
          09-07-2024, 05:50 AM
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • ChristianBr01
          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
          by ChristianBr01
          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
          04-23-2025, 01:48 AM
        • Jackching
          Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
          by Jackching
          I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
          04-15-2024, 05:14 PM
