Part RJP30E2 IGBT replacement part
  • Kokey
    • Mar 2016
    • 10
    Re: Part RJP30E2 IGBT replacement part
    Was thinking same thing to get a computer fan over both boards
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Haha sorry shows my maturity but yeah seems legit the word "shit" and this Tv in the same thread I also when rebuilding some Q97 Samsung Plasmas add fans in them to cool the Ymain and Psu. Keep us updated on what you do
      • Kokey
        • Mar 2016
        • 10
        Thanks Reecy il keep u posted on how it all worked out ����
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Awesome
          • Kokey
            • Mar 2016
            • 10
            Reecey success 😀It's working great right away it fired up . Now I need an upgrade and some fans and it's all good
            • Kokey
              • Mar 2016
              • 10
              Here is a pick of how it works Click image for larger version
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                Wow that's awesome, good work. Can you get us some images if you add some fans to it too ?
                • Kokey
                  • Mar 2016
                  • 10
                  Oh yes once I get the fans in and locate a 12v source on the bord that is not going to interfere with the operation of the tv ��
                  • Kokey
                    • Mar 2016
                    • 10
                    Oh yes once I get the fans in and locate a 12v source on the bord that is not going to interfere with the operation of the tv 👍
                    • tech2014
                      • Aug 2014
                      • 807
                      awesome
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Any 12v should be fine and not cause any issues all though running them atb12v might be a little loud so try 7v or 9v maybe.
                        • Folxs
                          • Nov 2016
                          • 167
                          • Poland
                          #32
                          Hi, I also found 3 broken IGBT RJP30E2 transistors in the Samsung Plasma PS42C450B1W and one broken SF10A400H diode - how do you think, just replace these components or some more? I'm afraid that if I change them, they will break down again
                          PCB 42U2P_Y-MAIN
                          • bododot
                            • Apr 2012
                            • Philippines
                            #33
                            PCB 42U2P_Y-MAIN
                            i encounter too like on what you show on your image. The difference is the 3 traniz is SGPF4536 same diode SF10A400H it is samsung plasma display model: PS51E470AIR. Hard to find this parts in my area.
                            • Folxs
                              • Nov 2016
                              • 167
                              • Poland
                              #34
                              I bought them on Aliexpress - but TV still doesnt work ;/
                              • whitspirit
                                • Sep 2008
                                #35
                                Hello.
                                I have one board like this ( LJ41-08592A) with 3 IGBT shorted and two diodes, and I desolted all 4 IGBT, when I returned to assemble the new ones, I noticed that there was 1 IGBT which is RJP63F3 and the other 3 are RJP30E2 and now I do not know where to install the RJP63F3 because I do not have the electrical scheme and i´m lost, I would appreciate if anyone can help me solve this dead end situation.
                                It can be :Q5003, Q5007, Q5000, Q5008, Q5013 ?
                                Thanks.
                                Carlos Silva.
                                crying:
                                • whitspirit
                                  • Sep 2008
                                  #36
                                  I found out by my self, I just had to dig more on the net.
                                  thanks anyway.
                                  D5004-sf10A400H
                                  D5003-RJP30E2
                                  Q5007-RJP30E2
                                  D5000-STTH02R06FP
                                  Q5000-RJP63F3
                                  Q5008-RJP30E2
                                  D5003-SF10A400H
                                  Q5013-K10A60D
                                  • the_rem
                                    Unknown transformer : how to find a good replacement part ?
                                    by the_rem
                                    Hello guys,
                                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                    04-23-2025, 01:48 AM
                                  • FreakyMex
                                    Trouble to identify part (Lunii screen) for replacement
                                    by FreakyMex
                                    Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                                    I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                                    02-17-2025, 01:16 AM
                                  • edugimeno
                                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                    by edugimeno
                                    Hi There!
                                    I'm trying to help my friend who owns a restaurant be just bought.
                                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                    09-05-2024, 09:34 AM
                                  • G-Sting
                                    iPad Pro A1876 SHORT Part Identify Help Needed
                                    by G-Sting
                                    So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                    So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                    i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                    SO My main concern is what part should i order what should i search the name for ?
                                    on Ipad...
                                    05-15-2025, 09:30 AM
                                  • Cvrado
                                    Led TV Board Replacement, same part number and model, different size
                                    by Cvrado
                                    Hello my friends!
                                    I have a question that I think you can answer and help me with!
                                    I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
                                    So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
                                    My concern is that the board won't draw enough voltage to the bac...
                                    03-02-2024, 05:05 PM
