Panasonic TX-P50G10E Panel or dust?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey Guys ,
    I can buy this tv really cheap but i need some advice.
    It will run fine for some time and then after a while this vertical line appears.
    Is this a a connector that needs to be reseated? For example , that it expands deu to tv/ribbon cable heating up? Or dust issue?
    If its a panel failure , it would be visible from the beginning right?
    Thanks.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic TX-P50G10E Panel or dust?
    Possible panel driver failure if thats the case its unfixable as they are bonded to the panel. Try re-seating sll the connectors for that section of the screen.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      I dont have the TV yet , i can buy it but need some advice
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I would say leave it tbh too much risk of it not being fixable.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Hmm ok , but if a IC fails it would be visible right away...right?
          It could not be a connector thats not placed correctly in the socket? Or dust.
          • vinceroger69
            • Mar 2012
            • 6714
            Depending how cheap the set is if it is not a badly seated ribbon cable etc maybe you could resell the boards as you know there working to get your money back and may even make a profit.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              I can get it for 80$.
              Im suspecting its a badly seated ribbon cable as the lines on the screen appear after a while.
              Its probably not seated correctly and because of the heat it expands and starts to display these lines.....
              OR the ic is bad and it displays those lines because of heat?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Possibly the Ic, up to you as Vince says if it it the Ic and its unfixable you sell the boards.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  is 80$ cheap for a set with this fault? im not sure what your prices are like over there would you make the money back if the set is unrepairable.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    Hmm , Im taking your advices and im not going to buy the tv.
                    Its 75 euro which is like 60gbp.
                    Thanks guys
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      Thought about it and i bought the tv. Tv is working perfectly , it was just a badly seated ribbon cable and dust.
                      50" Panasonic viera tv with a Neo plasma screen for 60 gbp is not bad right?
                      • tw2005
                        • Oct 2011
                        • 6458
                        Braver man than most. Well done. I would have walked on this one. What had me interested was not the vertical but the irregular horizontal jaggered lines off it.
                        So do you want to tell us which ribbon? I'm curious.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          Well , 75 Euro for this tv is not much as all parts are working.
                          Im not sure which one it was. I removed all 4 heatsinks in the centre and cleaned the cables. I noticed that some screws were not tightened that good , reassembled all the parts and its working perfectly.
                          Maybe it happened when the owner removed the stand ?
                          I love panasonic plasma's!
                          • tw2005
                            • Oct 2011
                            • 6458
                            Enjoy them while you can, finding a dud one to fix over here is near non existant.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Good one
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • howardc64
                                Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                by howardc64
                                Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                • Backlight on, no image
                                • Disconnect right buffer board (view from front), left side display comes on
                                • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                • Buffer board is pretty simple
                                Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                07-11-2025, 04:04 PM
                              • howardc64
                                LG 49UJ6500 LCD panel lighter band that goes away
                                by howardc64
                                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                02-19-2023, 12:13 AM
                              • triplefour
                                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                by triplefour
                                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                tcon is built into mainboard.
                                Only one cable goes to panel boards.
                                there is a cable from one panel board to the other that links them.
                                cost cutting measure that results in us having harder time to diagnose.
                                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                07-28-2022, 07:59 PM
                              • Storyteller12
                                QN55Q60R Service Menu Panel Help
                                by Storyteller12
                                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                01-13-2024, 01:57 PM
