Samsung 50 Inch Sound Ok No Screen
  • Wingryder
    • Oct 2015
    • 83
    Here is what I have. Samsung PN50 A400C2d Plasma set. Plug it in and it will cycle and click over and over. Off/on button has no effect. Removed X board plug no change. Replaced X plug, Removed Y Board plug and Power Button and remote will power on the set with jingle and turn off the set also with jingle. Audio is there and the logic board has a heartbeat led.
    Va and Vs are available at plug going to Y Sus. Va is 63 (panel 56) and VS is 230 (panel 208) I think these are high because Y sus is not connected.
    So I am assuming I have a shorted YSus board or buffer board which are one and the same on this set.
    I read elsewhere on the forum that in a similar case several FET's on the heat sinks were shorted so thought I would start there. No obvious cap problems.. or visible damage to board.
    Am I on the right path?
  • awyatt2
    • Feb 2012
    • 407
    • america
    Re: Samsung 50 Inch Sound Ok No Screen
    does the panel prime, can you see any light at all on the screen when you try and start it in a darkened environment?
    • Wingryder
      • Oct 2015
      • 83
      awyatt2
      No light at all on panel. With the y sus board connected it just keeps cycling no jingle.
      Disconnected it powers right up with jingle but no light either way.
      • Wingryder
        • Oct 2015
        • 83
        I removed the board and checked for visible damage. Nothing seen. Then I put the board back in and only hooked up the power connector. Same result.. Power cycling.
        My limited skills are now looking for a short.
        Thought I found it with a 0022uf cap that read dead short in circuit.. but ok out.
        suggestions?
        • Hamie
          • Apr 2014
          • 1383
          Turn your vs and va down to match the sticker
          • comptek
            • Aug 2013
            • 606
            • uk
            plug your y board in but unplug buffer board/s this will prove y board or buffer board/s
            inspect buffer chips for holes or marks
            • Wingryder
              • Oct 2015
              • 83
              thanks Comptek for your help. However in this case.. Buffer boards are built into the Y sustain. Did not find any shorts on the buffer test.. but still have not ruled it out.
              Hamie.. I will try turning down Vs and Va. I have tried measuring with everything connected and I get nothing. Could be my cheapo meter is just too slow. Maybe if turned down.. it will stay on long enough to test.
              How do I tell if the FET's are shorted ?
              • Wingryder
                • Oct 2015
                • 83
                There are 13 FETs on the heat sinks. I show 500 ohms drain to source on two of them and direct short on five others. That just can't be right.
                • Wingryder
                  • Oct 2015
                  • 83
                  Ok small headway.. It seems the VS line is shorted to ground. Will trace it out tomorrow without the turkey blues and see what is killing it.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • mrtek
                    Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                    by mrtek
                    Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                    11-26-2024, 09:58 AM
                  • ohren
                    Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                    by ohren
                    I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                    I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                    The models launched in 2018 and 2019 respectively....
                    09-08-2023, 05:24 PM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • mar1in
                    Samsung TU8000, backlight and sound on, stuck in blue screen
                    by mar1in
                    I've got this Samsung here that would be stuck in a boot loop.
                    After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                    Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                    Thanks in advance
                    11-08-2023, 05:43 PM
