Pioneer PDP-42-A3HD
  • vovay45
    • Nov 2015
    Pioneer PDP-42-A3HD
    Pioneer PDP-42-A3HD
    When I turn power ON
    1.Green light is ON
    2.I hear some relay switching on and off but nothing on display and no control.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Pioneer PDP-42-A3HD
    Take some pictures of the back side of the tv and the boards.
      03-31-2024, 02:12 PM
      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
      I was working on this CNC machine today found no keyboard functioning no control relay powering on
      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
      Found shorted diodes on main controller relays there are 3 of them that...
      01-07-2023, 05:43 PM
      07-01-2024, 06:34 AM
    • GraphicMan
      Pioneer amplifier A-205 Relay not clicking after a mistake i made
      by GraphicMan
      Hello guys
      Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
      sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
      i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
      on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
      05-05-2024, 06:20 AM
    • tmcw
      Fridge - Gram
      by tmcw
      Have this fridge, laboratory grade unit, not working fully.
      It's designed with a chilling unit at the top, on the inside, and a fan just below that. When the door is closed, the fan blows the cold air down through the fridge, and when the door opens, the fan switches off, presumably so that it doesn't blow all the cold air out.
      The fan isn't switching on, so in addition to not having uniform cold throughout the fridge, the chilling tubes tend to ice up. I took the lid off the top, electronics are in the lid, and when the door is opened and closed, I can hear the relevant...
      10-10-2023, 05:00 AM
