Sony KDL-52EX703 LCD No 12 volts
  • tech2014
    • Aug 2014
    • 807
    I have a sony lcd tv that has no 12v. I found 2 shorted mosfets and a blown resistor. I replaced the parts, and there is still no 12v. The power supply has APS-262(CH). I can't find a service manual or schematic for this. Does one exist??
    See pics of tv.
  • corrize
    Replacing resistor fuse in Sony DV charger
    by corrize
    Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
    So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
    It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
    06-30-2025, 06:59 PM
  • x_orange90_x
    Sony Bravia KD-50X690E blown resistor
    by x_orange90_x
    I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
    The power supply is 715G8413-P01-001-0H2S...
    07-16-2024, 06:53 AM
  • zaurus81
    Asus TUF Gaming F16 (2024) FX607J no power no ACDRV
    by zaurus81
    Hi all, I have a Asus TUF Gaming F16 (2024) FX607J motherboard with liquid damage. The oxide on the board was removed before giving it to me. This made it more difficult to repair. Also they did not give me the power supply.
    When I connect the 20 volts with the bench power supply I get 4.3 volts on the main power line. If I remove the power sensing resistor I get 20 volts on one side (first 2 mosfets are ok) and 4.3 volts on the main power line (see photo). How is this possible?? I thought the 4.3 volts was coming from the battery mosfet so I unsoldered it and tested it. It is ok too. I...
    11-21-2024, 05:04 AM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • mikey5791
    Need help to replace burned resistor in 350w atx psu
    by mikey5791
    Hi to all forum members,
    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
    12-26-2024, 04:55 AM
