Philips 32PFL3088H/12 reboot loop
+ More Options
Posts
  • angel-boy
    • 550
    • Romania
    - when starts philip logo appers, after that no image on background , only light, in short time , is restarting and power up again with philips logo without background
    mainboard 715G6079-C0D-000-004K
    i read something on internet to change firmware ?
    any help ?
  • angel-boy
    • 550
    • Romania
    Re: Philips 32PFL3088H/12 reboot loop
    any help ?
    • sordids999
      • May 2013
      • 2158
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      • angel-boy
        • 550
        • Romania
        • angel-boy
          • 550
          • Romania
          help now ? or this is your text allways ?
          • victor_cj
            • May 2015
            • 90
            • Romania
            On the back side of the motherboard you a have a Samsung NAND flash memory may have bad soldering or bad software.
            The art of fighting without fighting
            • danalex123
              • Dec 2015
              • Romania
              I have the same problem on my 32pfl3088h/12. Did you manage to fix problem on your TV?
              • thoma
                • Sep 2012
                • 268
                http://www.p4c.philips.com/cgi-bin/d...=32PFL3088H/12
                • thoma
                  • Sep 2012
                  • 268
                  http://toengel.net/philipsblog/2013/...08er-tv-serie/
                  • kevin_allein
                    Samsung GU58TU7199 reboot loop
                    by kevin_allein
                    Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
                    The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
                    03-24-2024, 12:19 PM
                  • natiz
                    Samsung QE50Q60AA - Reboot loop
                    by natiz
                    I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
                    Disconnecting the LVDS cable stops the restart loop but no image.
                    I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
                    Tested the caps on the left buffer board, no beeps.
                    What else can be checked?...
                    08-30-2024, 09:26 AM
                  • nocnoc
                    Acer Swift 5 (SF514-52T) reboot loop mistery
                    by nocnoc
                    I'm quite new to this and trying to learn by help a friend with his SF514-52T that stopped booting after battery was replaced. I suspected the battery was bad but the problem persisted when putting back the original one (which is was still working although with reduced capacity).
                    When pressing the power-on button the symptoms are:
                    - Keyboard backlight and blue power LED turn on for about 5-7 seconds, and then flash off-on in ~3 seconds cycles (reboot loop).
                    - Display does not seem to turn on, although it sometimes seems to flash in between reboots....
                    04-21-2024, 06:42 AM
                  • Yanleb
                    Samsung 4K UN55NU7100F stuck in a reboot loop
                    by Yanleb
                    Ok, I have this Samsung 4K UN55NU7100F that is stuck in a reboot loop.
                    I know this is not a backlight issue since when I disconnect the power cable from the main board the power supply starts and the backlight is working just fine. Each of the 6 LED strip connectors measure 116 volts.
                    I've found that when I disconnect any one of the two LVDS cables going from the main board to the LCD panel (it doesn't have a T-CON board) it is working just fine (with no picture as you can expect).
                    On a few occasions I found that reconnecting the disconnected LVDS...
                    03-19-2022, 02:13 AM
                  • betmen
                    TV Philips 40PFT4101/12 - power on loop
                    by betmen
                    TV is Philips 40PFT4101/12, power supply 715G6934-P01-000-002M, motherboard 715G6947-M002-000-004Y (703TQGPL068).
                    The problem is that when it is plugged in, the TV turns on by itself, the Philips sign appears, the backlight turns on and off a couple of times, and the TV turns off, and so it repeats itself in a circle. It does not respond to the remote and nothing is written on the screen, the red light does not blink.
                    A few weeks ago, it used to turn on by itself about once a week, but after that it worked, now it doesn't work.
                    I checked the power supply, voltages are fine,...
                    11-05-2023, 05:45 AM
