50PX4D-EB works but bad picture.
  • diif
    • Feb 2014
    • 6978
    • England
    Works but a bad picture. On powering up i've heard a crackle and a pop that sounded to come from the ZSUS.
    VS and VA measure fine.
    Searching around i am suspecting the IPM module. Putting my hand on the heatsinks on the YSUS and ZSUS the top ones are warm the bottom ones are cold.
    Would this suggest that the YSUS has failed as well as the ZSUS ?
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: 50PX4D-EB works but bad picture.
    I would guess that it's only the ZSUS based on the first picture. A failed YSUS on these 50X3 based LG plasmas would almost always result in a no picture scenario.
    • diif
      • Feb 2014
      • 6978
      • England
      Thanks, yes the fuse is fine. I'm going to pull the module off later.
      • diif
        • Feb 2014
        • 6978
        • England
        I managed to remove the top module from the board but couldn't see any damage through the clear silicone.
        The bottom module had black silicone inside so I couldn't see if there was any damage.
        Managed to find a ZSUS delivered for a good price and this has fixed the issue.
        • PlasMatt
          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
          by PlasMatt
          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
          09-20-2025, 06:50 PM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
