Samsung PN64E533D2FXZA Plasma Sound But No Video
  • Regor
    • Nov 2015
    • 7
    TV has been coming on without video for quite a while. But if you turned it off and then turned it right back on, it would come on with video. If after watching it for say an hour or more, if you turned it off, it would need to cool down for at least half an hour before you could get it come back on. Well, it finally quit coming on at all. Took the back off and nothing looked cooked. Took some voltage measurements as suggested by Samsung training video. All seemed well:
    Standby=5.27V
    PS On-3.3V
    PS On drops form 3.3V - 0V when tv is turned on.
    VS On rises from 0V - 3.3V when turned on.
    Next step was to observe the green blinking LED on the Logic board. It blinks off once every 5 secs instead of normal state which would be once per sec. The video says then that there is a problem with Y-main, Y-buffer, or X-main boards.
    Next step it says is to check Vs and Va voltage. Vs rises to 217 and immediately slowly falls. Va rises to 55 and immediately slowly falls. So this is where I'm at.
    I shorted the PS on to gnd on the cable to the main and Va and Vs reacted the same. I guess that was just to eliminate Main board as problem.
    I've searched all internet for a new Y-main and all are out of stock. None even on eBay. Am going to pull the Y-main and cool it down and retry to see if tv will come on. Any ideas on what to look for on the Y-main board or where to source a replacement board?
  • Regor
    • Nov 2015
    • 7
    Re: Samsung PN64E533D2FXZA Plasma Sound But No Video
    Here is a link to the video I was following:
    https://www.youtube.com/watch?v=JjrwTZC5nVg
    My Y-main number is BN96-24770A (LJ92-01906A).
    • Regor
      • Nov 2015
      • 7
      OK. So I put the S-main board in the freezer for couple hours and re-installed it. Powered right up with video and everything is working fine. So I still have a problem in that I can't source a replacement board. Any ideas on what to replace on the board?
      • Jerryv
        • Oct 2012
        • 22
        Are any of the electrolytic capacitors bulging? Sort of shotgunning, but it wouldn't hurt to replace them.
        Jerry
        • Regor
          • Nov 2015
          • 7
          No, all look fine. Set continued to power up normally for a good while. 2 hours after re-installing after deep freeze, it's back to no picture. I cant see much on back of board either as banks are encased in some gray insulating material.
          • ajshoe
            ajshoe
            • Dec 2012
            • 477
            • usa
            how about some pics of board - both sides
            • DyerTM
              • May 2016
              Hi Regor,
              Did you ever find a solution to this issue? I have the exact same TV as you, I've got sound, but no picture. I've run through the same troubleshooting steps, the voltages are all spot on, but like you fall off immediately. Unfortunately everything is pointing to the Y-main; however, the only one I can find is on Ebay for $200... Not gonna happen at that price!
              The one thing I'm curious about after reading everything I could find is whether or not it could actually be a faulty logic board considering the fact that it seems to control everything. I just hate to give up on this TV as it is in pristine condition and was an amazing piece of my home theater...
              -Troy
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Did the freezer work for you?
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  Check the solder joints on the powersupply,Q802,Q804 are notorious for cracked solder joints. And check tho other ones too
                  Might be a shot in the dark,but I've repaired a few of these where that was the problem,resulting in the powersupply to self destruct.
                  Proud owner of dozens of broken TV's and many,many,many boards.
                  Our website and passion:http://hollenhundshepherds.com/
                  • gl4709
                    Samsung un55cu7000d with backlight and sound No Video / Picture
                    by gl4709
                    I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                    01-23-2025, 06:21 PM
                  • Max514
                    Samsung UN55H8000 sound but no backlight no video
                    by Max514
                    Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                    The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                    I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                    • Unplugging the main board cable at the power supply >>> backlights came on.
                    • BLU_ON signal from the
                    04-14-2022, 10:34 AM
                    09-07-2024, 05:50 AM
                  • soeren
                    A2442 - No sound over internal speakers and no video playback
                    by soeren
                    I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                    All happened after the battery ran out of power overall several days when I was on vacation.
                    I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                    07-26-2024, 01:24 AM
                  • JRade
                    Audio video receiver KENWood KR-V990D,no sound
                    by JRade
                    When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                    The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                    I replaced the capacitor C303/0.047F, nothing changes.
                    I'm asking for help, what should I do next?
                    Thanks in advance!...
                    08-05-2025, 10:23 PM
