I picked up this TV online, without knowing that it had problems. When I brought it home, it showed weird colors on poweron but it cleared up after say 5 minutes of running. I removed the SC (Ysus) board to inspect it up close, found nothing shorted or tampered with, so I put it back in, except I didn't put all the grounding screws. Upon power on, something blew on the SC board and gave me 6 blinks. Pulled it again, and upon examining up close, saw Q621, & Q661 shorted. Also IC773 (I think is an inverter) was shorted vdd/gnd. Ordered these parts from China and replaced them today, now the TV does fire up, the screen looks good for 2 seconds, when it starts pulsing with weird colors messed up at the same time. After a minute, the pulsing stops, but the weird color problem stays. I didn't keep it on longer than 2-3 minutes at a time, worried something might blow. At this point, looks like the repair is stable (it survived several power on attempts), but seems to be back to square one where I started. I have attached two pictures, first one immediately after power on (looks good) and the second after 2-3 seconds (colors messed up). Any have have any ideas what is going on here?
Panasonic Plasma weird colors, screen pulsing
Re: Panasonic Plasma weird colors, screen pulsing
What is the model number of the TV?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Its a TC-P50C2. I noticed today that if I set the picture settings in the menu to be "Standard", it does the flickering and display poor color. However, if I set it to say "Cinema" or "Vivid", it looks good (no color distortions). Also, although unrelated, there is a faint greenish line across the screen right at the middle, several pixels wide. It is probably related to aging buffers, but I thought I'll mention it here. So really confused.Comment
I thought this could be a Vsus problem. The measures Vsus was 189 volts when it first fired up and drops to 174 once the screen comes on. There were no labels on the screen stating what the Vsus value should be, but the service manual seems to suggest a value of 198. I increased the voltage slightly and now the picture looks good in all different picture modes. My guess is that the guy who sold it to me played with the Vsus settings trying to get what was a SC board issue to work, and lowered it to compensate for some weak component on the SC board.Attached Filesif you find these attachements useful please consider making a small donation to the site
I take that back, the problem still exists if I set the picture settings to "standard". It works fine in "Vivid", "Cinema" etc. No idea what is causing this. At this point I dont think it is a VSUS or SC board issue, as the behavior of the SC board should not change based on the software picture settings. May be worth trying an software update? But this thing needs a SD card.. sucks..Comment
Not sure anyone is paying attention here, but looking in the service menu, I see that the last 3 blink codes had been 8,6,6 and the first 2 had been 6 and 6. So I wonder if the blink code of 8 has anything to do with what is happening with the colors. According to Panasonic this is related to SS FPC detect. Does anyone know what that stands for?Comment
Drive signals get generated from the control board and that being I believe on your model the control board is integrated with the main board. What kind of vsus are you getting in vivid or custom modes?Did I leave the soldering iron on?Comment
Have you tried tweaking the vsus slightly higher in standard mode to see if problem starts to dissappear?Did I leave the soldering iron on?Comment
Also check that the Lvds cable is properly seated its a red cable I think on this model.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
The Vsus voltage as measured by one of my multi-meters jumps around in the 140-180 range. It varies a little bit ( I think it increases), in the custom mode). Out of curiosity I attached an older multimeter in parallel, and the Vsus read more stably on that one, at about 188 volts. Not sure if the older multimeter does a better average than this other one. Did I mention that in the service mode, if I try the "Vsus test", which is supposed to produce a white screen, instead produces a flickering screen, almost as though It cannot handle a fully white screen. Ill try to posy a video of it when I get home. This is a really strange problem to say the least.Comment
How many hours are on the panel?
I wonder if what the voltage is from the scan drive to the buffers on a full white screen? Have you tried applying heat to the SC board while you have a full white screen and its flickering?Last edited by freakaftr8; 11-09-2015, 11:40 AM.Did I leave the soldering iron on?Comment
I made a video of the TV problem, can be seen here:
https://youtu.be/3SSyoCW5XTwComment
A little more update on this problem. As luck would have it, someone in my town was selling this very same tv in fully working condition, so I bought it for the purpose of swapping boards to isolate this problem. To my surprise the A board (main board) seems to be the problem. Installing the problem A board in the known good tv recreated the color distortion and Vsus test issues. No idea what could be causing this, at least I won't be engaged in a wild goose chase here.Comment
by jm1234Hi,
anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
I checked that board for any obvious faults... -
by stecosHi everyone!
For my passion for technology I'm now collecting several... -
by LITEZONERforgot to put the model number in the last post, could not edit it, guess I waited to long. anyway, has anyone seen this weird issue on one of these plasma sets, I was thinking maybe a loose ribbon, but wanted to check if anyone had seen this before. thank you...10-22-2021, 09:27 PM
by speggio91Hello everyone!
I have this board that got slightly water damanged and it is stuck at S5 state. It pulses once every 5 seconds.
When connected the magsafe 2 to the bench psu, the current goes from 0.02A to 0.10A when is pulsing.
When using the genuine magsafe 2 charger, the light turn on and it became green and then amber. The fan is not spinning.
When I tried the SMC bypass mode, the fan spins a quarter every 5 seconds and the pulsing is still present every time the fan spin.
The pulses are present in the CPU Vcore rails on L7320 and L7310.... -
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM - Loading...
