Bush s642f factory reset
  • Rickig
    • Mar 2015
    • 112
    • England
    Finally got the set powered up but it won't tune.
    It stays on atv 901. Checked the locks and all off so want to try a factory reset but can't figure it out.
    Any body know how to do a factory reset on a bush?
  • Rickig
    • Mar 2015
    • 112
    • England
    Re: Bush s642f factory reset
    Managed to do a factory reset but still not finding any freeview.
    Any suggestions
    • jczarniak
      • Oct 2015
      • 179
      Any suggestions
      I've got same TV and same problem.
      Did you managed to fix it?
      • jczarniak
        • Oct 2015
        • 179
        How to do factory reset, please?
        • jczarniak
          • Oct 2015
          • 179
          Managed to do a factory reset:
          MENU, 8, 8, 9, 3
          but still not finding any Freeview channels.
          Any suggestions?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Is it scanning for channels and saying none found?
            • jczarniak
              • Oct 2015
              • 179
              Exactly, 0 channels found.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Have you checked the voltages on the tuner? It may have lost it's supply.
                • jczarniak
                  • Oct 2015
                  • 179
                  Not sure how can I do that.
                  Recently changed 4 caps on power supply (4 x 470uF/35V), screen backlight was flickering. OK now but no Freeview.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Does it have both an analogue and Digital tuner. If so are you auto tuning the Digital channels
                    • jczarniak
                      • Oct 2015
                      • 179
                      Has got both tuners.
                      I'm auto tuning both, tried separately also.
                      Result is 0 channels found for both tuners.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Have you got a schematic?
                        Can I assume that all the other inputs are working?
                        Does it say "XX Channels found" but just not storing them?
                        • jczarniak
                          • Oct 2015
                          • 179
                          No schematic.
                          All inputs are working.
                          It say: 0 Channels found
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Can you guarantee that you have a strong signal from your aerial. Have you plugged the aerial into another set to be certain it's not an aerial/aerial cable fault.
                            • jczarniak
                              • Oct 2015
                              • 179
                              Yes, aerial is fine, working absolutely fine on other TV.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Can you supply a sharp photo of the power supply connector showing any legend alongside giving the voltages read.
                                Can you also supply a photo of the main board.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  There appears to be a 5V regulator feeding the tuner and several metal oxide resistors around the tuner you could check out.
                                  • jczarniak
                                    • Oct 2015
                                    • 179
                                    Good idea.
                                    I'll check that.
