Samsung 32 Inch LED no picture but sound
  • Rob11x
    • Oct 2015
    • 5
    • Ireland
    Hi.
    As the title says, my 14 month old Samsung LED telly has sound but no picture. I think I have the problem boiled down to the power board. So can somebody that knows their stuff look at the following pictures and tell me if I am right!
    The first picture is of the power board itself. The second picture is a close up of the part I think is causing the problem. There is brown stuff at the end of the pins. I don't think it should be there. Is it burn marks? Could this be the cause of my lack of a picture on the TV? Cheers!
    Re: Samsung 32 Inch LED no picture but sound
    Check the DCV of each pin of that orange LED connector, you will have the leave the meter in place while doing this, you will turn the TV on and look at the meter to see if the Voltage jumps up high and then go low on each pin, you will have to repeat the power on power off for each pin. I will not be surprised if it has bad LEDs.
    Is the board BN44-00505?
    • Rob11x
      • Oct 2015
      • 5
      • Ireland
      Thanks for all that info budm! Will check the board number later when I get home from work. So you don't think all that brown stuff at the ends of the pins in the second picture is anything to worry about? As for bad LED's, when I turn the power on the telly I can see light coming on behind all the power and main boards.
        'So you don't think all that brown stuff at the ends of the pins in the second picture is anything to worry about?' Just left over flux, you can clean it off with Alcohol.
        'As for bad LED's, when I turn the power on the telly I can see light coming on behind all the power and main boards.' So the lights stay on but you see no pictures then? If you look at the front of the TV in the dark, do see faint glows?
        • Rob11x
          • Oct 2015
          • 5
          • Ireland
          Actually yes, the telly does glow in the dark! Is that a good or bad sign?
            That means the backlights are OK, but either the T-CON board is dead (blown fuse) or the main board is not sending the Voltage to the T-CON board to run, or not sending the signals to the T-CON. You will need to check the DCV between the chassis and each ends of the SMD fuse on the T-CON board.
            • Rob11x
              • Oct 2015
              • 5
              • Ireland
              Wow, great stuff! You sure know your way around these things!
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • Dodgethis
                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                by Dodgethis
                Hello all,
                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                09-11-2024, 07:39 AM
