Sanyo IC5750 replacement problem
  • ridgerunner
    • Feb 2014
    • 9
    I have a Sanyo DP42849-01 that had the problem where the green power led would come on for 10-20 seconds, then recycle. The set would never power up. I replaced IC5750 on the main board, I had the hynix chip, not the quimondo, and now the set will seem to power on but it sounds like machine gun fire through the speakers and no picture. I seems as if the main board may be cycling on and off rapidly. All voltages look good on the power supply side.
    Any ideas?
    Thank you
  • mferna14
    MacBook Air A2681 battery problem after Screen Replacement
    by mferna14
    Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
    12-06-2024, 08:10 PM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
  • NConstantinou
    LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
    by NConstantinou
    Dear all,
    i have the above laptop which had a problem with battery. i replaced it with a compatible one..
    the laptop DOES NOT POWER ON..
    with it old battery it does power on.
    i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
    when i shutdown the laptop does not power on.
    does anyone have any solution!
    when is not power on the usb c voltage tester shows 5v 1.3A
    when i disconnect battery and power on and then connect battery the tester...
    12-10-2024, 04:52 AM
  • Zeonalbasta
    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
    by Zeonalbasta
    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
    09-13-2024, 01:17 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
