RCA LED32B30RQ T con Help
  • Rusha
    • Jan 2015
    • 8
    I just pick up this tv on yard sale. owner mention that tv has sound but no picture.i try that there is a sound but no pic. so open back cover and find out
    T CON ribbon was came out.
    i try google to find service manual. but i could find it. dose anybody has service manual ?
    Rus
  • Hamie
    • Apr 2014
    • 1383
    Re: RCA LED32B30RQ T con Help
    This isn't fixable.
    • Hamie
      • Apr 2014
      • 1383
      edit: just rechecked the picture, thought the ribbon was ripped.
      • Hamie
        • Apr 2014
        • 1383
        Can't make out, is that ripped?
        • Rusha
          • Jan 2015
          • 8
          When i open back cover i was loose so i just pull out.it comes out easy.
          • Hamie
            • Apr 2014
            • 1383
            The orange tab is it connected to the panel?
            • Rusha
              • Jan 2015
              • 8
              no, i just open front frame. nothing on screen.
              • Hamie
                • Apr 2014
                • 1383
                if that orange tab is not connected to the panel then the tv is not repairable.
                How did the orange tab get ripped?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  So the yellow cable at the top of the Tcon has come out ?
                  • Rusha
                    • Jan 2015
                    • 8
                    yes, yellow ribbon still connected with tcon board but came out from screen.
                    • Rusha
                      • Jan 2015
                      • 8
                      i took front frame out.
                      • Hamie
                        • Apr 2014
                        • 1383
                        No it's not fixable. You won't be able to reattach that.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Its trash you will need a whole new Lcd screen that isnt economically repairable.
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • danielgerman681
                            ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                            by danielgerman681
                            Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                            08-27-2025, 01:17 PM
                          • Grouickman
                            Hofmann geodyna 6300 Wheel balancer
                            by Grouickman
                            Hi there,
                            First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                            Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                            I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                            I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                            03-31-2025, 05:29 AM
                          • corrize
                            Where to find a very small fpc connector 0.3mm between 2 pins ?
                            by corrize
                            Hello, I search this connector (oxydated).
                            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                            Do you know how to find this connector please ? What is the exact name for find it ?
                            08-06-2024, 05:25 PM
                            Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                            by sam_sam_sam
                            This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                            Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                            07-07-2024, 02:34 PM
