Just getting around to troubleshooting my faulty Panasonic TC-P42X3. After a vacation this summer we came back and the unit wouldn't power on. The red power LED would blink 14 times. Did some searching...I tried checking for a short from chasis ground to pin 1 of P2 and it was a short, then I disconnected the cable to the other board and checked again and it was again a short. So this means it's the power supply board right? Again, P2 pin 1 to chasis ground was short with both the cable connected and disconnected.
So now that I have determined that and found that they are $100+ IF you can find them in stock, I thought I would try to troubleshoot at a component level and I need you all's help
I've attached some pictures. There are two fuses that I would like to check but I need to lift one lead correct? These fuses are weird in that they have seats that are soldered and make the fuse non-serviceable w/o desolder of one lead.
So let's start this chase I hope someone here can give me some guidance.
Thank you,
Roy
Thank you,
Roy
