interesting vizio 42"
  • ozzy214
    • Nov 2013
    • 319
    • usa
    Well this is interesting. I just fixed a 42" vizio, older one. Got universal replacement ballasts for it that stick to the back via magnets. New cables, etc.
    Well the interesting part. It wouldn't start still. I was getting 24v to one ballast, not to the other. Swapped a main board quick and same thing.
    Hooked old mainboard up and now it wont turn on voltage to either ballast.
    I started getting frustrated and starting pushing the power button rapidly and it fired up....
    Now working normally. Interesting creatures, these vizios. Hmm. Only thing that makes sense is I literally watched the old ic chip on the ballast smoke and burn on start up. So maybe a breaker of some sort was tripped on the psu and it reset itself?? Idk or maybe it was the usual hold the input and push power trick budm posted once. Idk
    Hopefully this amuses someone as much as it did me....
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • bscottjohnston
    Interesting E60-E3 (Vizio) issue
    by bscottjohnston
    Good morning BadCappers,
    I picked up a Vizio E60-E3 yesterday. The donator claimed that it never powered on and that he checked Voltages at the power supply. I checked a handful of Voltages and then laughed when I realized I was trying to turn it on via the menu button on the back of the TV when its upside down on my TV repair bed (literally my guest bedroom).
    Okay so I took out the mainboard and decided to flux up the BGA and heat it up. Upon reinstall of the mainboard the TV does indeed power up but all of the screens have a blue hue AND the video displayed fails...
    08-31-2023, 07:41 AM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • mrtek
    Vizio M65-C1
    by mrtek
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
    07-14-2025, 07:28 PM
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
