UN40EH5300 Service Menu / Any Way to Rotate the Image?
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Quick question for you guys here. I have a Samsung UN60ES6100 sitting on my bench. The TV had a bad main board and the replacement is around $80-$100. I had a brand new main board out of a UN40EH5300 lying around which is of the same series minus the wifi option. I've installed it in the TV and it works, but the image is now upside down. I realize of course that the T-con was on the top of the screen on the 40" and is on the bottom on the 60". That being said, I saw in this thread the button sequence to pull up the service menu on a similar model.
    https://www.badcaps.net/forum/showth...ght=UN55ES6500
    My question is, does anyone know if there is an option in here (this would be the UN40EH5300 of course because that's the board I'm using) to rotate the display? I'd rather not spend the money on replacement main board if I don't have to. I guess an alternative would be to just sell the TV to someone that wants to mount it upside down but that may be a tough one.
    Thanks in advance,
    Aaron
  • Hamie
    • Apr 2014
    • 1383
    Re: UN40EH5300 Service Menu / Any Way to Rotate the Image?
    What about just changing it to 60" model settings?
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Hmmm. I hadn't had a chance to look at all the options closely and wanted to ask before I messed something up. I'm at work now but will see if there's a model option when I get home this evening.
      • chrismurphy
        • May 2014
        • 251
        • australia
        Re-flash firmware for UN60ES6100 should fix the issue
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Thought I'd let everyone know that after 30-40 tries at different screen selections followed by a factory reset each time, I found one that flipped the image. Apparently, there are more models that use screens with the T-con mounted on the top than the bottom. Anyway, I know have a working 60" smart TV for $10 plus the 40EH5300 board value (which I already had on hand). Only issues are there is one missing USB port and no wifi. Smart functions work fine when connected to Ethernet.
          • Hamie
            • Apr 2014
            • 1383
            Nice fix, can't complain getting a 60" tv for buttons.
            What settings did you change? Incase someone else is forced to buy to 40" board to fix their 60" model.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              You enter the service menu on this one by pressing mute, 1, 8, 2 power starting with the TV turned off. Once you are in it, you go to control then select the option to change the screen setting. The one that worked for me was 60HAxxxxx on this one. It still shows the base model as UN40EH5300 but the screen now shows as what I selected. I did unplug it for a few hours to make sure it didn't revert and seems to be fine. Just a note, the 46EH5300, 50EH5300 and I'm sure others are the same basic board as well.
              • aaronwt6
                • Apr 2013
                • 855
                • US
                Here's a couple pictures. First is upside down (you can see the Samsung logo at the top). 2nd is after changing the screen setting.
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                • tusiime
                  How to access Vizio m652i-b2 service menu
                  by tusiime
                  The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                  So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                  Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                  09-15-2023, 09:57 AM
                • Storyteller12
                  QN55Q60R Service Menu Panel Help
                  by Storyteller12
                  I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                  I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                  I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                  the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                  01-13-2024, 01:57 PM
                • notallbad
                  LG Service menu android app
                  by notallbad
                  I had been using wave audio files to play via the headphone jack to an ir led but had difficulty getting the InStop file to light the led, no sign of life when viewing the led through the camera app on my mobile phone.
                  Anyway, came across this free android app called IR Wave Plus that can utilise a homemade audio jack to ir led lead.
                  Not limited to just LG either!
                  A few settings require adjustment but the app itself is rather straightforward.
                  In settings ensure the slider bar is set to maximum and Force volume to 100% for audio ir blaster is ticked.
                  10-23-2024, 04:54 PM
                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:20 PM
