NEC PX-50XR5W (Plasma) Shuts down
  • Markus1
    • Jul 2013
    • 80
    Hi there,
    Seeking your guidance again.
    At Power On relay clicks, fans start to spin, then after a second or two the relay clicks again and all shuts down. A small red LED on the sub-board of the PSU starts blinking red.
    The front LED indicator at the beginning shows green, after shut down turns off and in about 20 sec turns on red.
    I did try to disconnect power to the Y-drive to observe a brief presence of Va (it is Vd on NEC) and Vs voltages before shut down. Nothing observed and no difference in sequence behavior.
    I could not find anything related to this model on the Badcaps, and had no luck with the PSU schematic search. Hence hoping for a good advice from you guys.
    Attached:
    - full view from the back
    - view of the PSU (with additional heat sinking plates removed)
    Any help will be appreciated.
  • Markus1
    • Jul 2013
    • 80
    Re: NEC PX-50XR5W (Plasma) Shuts down
    I would really need some direction on where to start with this shut down problem. Any suggestion? Any chance of a schematics for the Power Supply Unit? Will be greatly appreciated.
    • Markus1
      • Jul 2013
      • 80
      Still having problem with this TV, still calling for help. Possibly the issue is with Power Supply Unit but it is hard for me to move without the circuit diagram.
      Some internet searches indicate that possibly Panasonic used the same power board.
      In my case (NEC) the PSU is marked as KPC 2294V-0.
      Can any one confirm that it was actually used by Panasonic and in what TV model number?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        So does Vs shut down even with Ydrive not present ?
        • Markus1
          • Jul 2013
          • 80
          Thanks ReeceyBurger123 for you reply.
          Yes, PSU shuts down even when Ydrive is disconnected.
          • monrel
            • Dec 2016
            Hi!
            I have the 61 inch version of this screen and bought the service manual for it, online. It makes mention of your model number in it, a few times. Are you still looking for help with it? If so, I'll send you the PDF.
            P.S My screen is displaying EXACTLY the same problems as yours. Please let me know if you have any advice.
            • cloo
              Panasonic ZT60 plasma tv with strange behavior and 8 blink code
              by cloo
              I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
              It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
              So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
              After doing a factory reset this problem was gone and the picture was back to...
              01-06-2025, 06:02 AM
            • goldbird78
              LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
              by goldbird78
              Hi All, I have an LG 50PK550 with the EAX61392501/10 EAY60968801 power supply board. When I turn it on it clicks and shuts off immediately, I have unpluged the power wires to to Zsus and Ysus board and it does the same thing. I have read up and replaced IC301 & d304 and checked the R927 R929 and all 3 fuses on the board and all appear ok. Still does the same, shuts off immediately with or without the z & ysus board hooked up. Any help would be appreciated. Thx
              02-17-2021, 08:45 PM
            • bffargo
              2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
              by bffargo
              LG 60PB66550 NOV 2014
              PSU: EAY63168603
              PCB: EAX65359531 2013.11.01 Rev:1.0
              Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
              Symptom:
              While watching, just went black and started clicking relay every few seconds.
              Initial diagnosis:
              Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
              Deeper diagnosis:
              Pulling pins #1/#2 (Blue/Grey) from the connector housing...
              09-09-2022, 07:34 PM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • huzo
              HP Omen shuts down when loading OS
              by huzo
              The model is 15ec-1061nm
              Board number is DAG3EDMB8D0​
              SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
              10-29-2024, 12:05 AM
