HItachi P50T01UA plasma PSU Murata MPF7722
  • nogger
    • Aug 2010
    • 190
    hi All, just got one of these in for repair & trying to figure out how to power this PSU up on the bench. Searched the forum but can't find anything on the PSU OR the TV.
    One connector has the following pins STB5v, GND, STB3.3, POWEROFF,AC CLOCK,POD-STBY,REC-STBY. The STBY5v & STBY3.3 are present & correct.
    A second connector has : Vcc5.1,GND,STBY3.3,VCEG0,VSAG0
    triedthe usual tricks STBY to GNDetc but nothing clicks. There's no PS_ON as far as i can see just the POWEROFF.
    Before i go experimenting thought i would ask on here. As usual no circuit info in the manual.
    Cheers
    Graham
  • steviewonder
    • Dec 2013
    • 183
    • england
    Re: HItachi P50T01UA plasma PSU Murata MPF7722
    Yes,not come across one of those psu's so far.i would assume poweroff is the same as p-on?
    • nogger
      • Aug 2010
      • 190
      That's what i thought but seem's not, tried all combinations but doesn't switch it on. Have to see if i can find a manual.
      Graham
      • fzabkar
        • Mar 2009
        • 772
        The Hitachi DW3-A chassis pinout for CN63 is ...
        1 STBY+5V -->
        2 GND
        3 STBY+3.3V -->
        4 Power Off --> only high momentarily when AC removed
        5 AC Clock -->
        6 Power1 <--
        7 Power2 <--
        8 NC
        Therefore ISTM that 6 and 7 could be the power control pins.
        • nogger
          • Aug 2010
          • 190
          Haven't had a chance to test this yet, will have a go tomorrow & let you know.
          Graham
          • fzabkar
            • Mar 2009
            • 772
            Electrotanya has several service manuals for the DW3-A chassis. Perhaps one is more complete that the others.
            • KYBOSH
              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
              by KYBOSH
              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
              No picture but you hear the TV static (white noise) playing loud and clear.
              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
              But it seems they didn't get too far and just left it.
              When I first took a look I was amazed at how pristine the inside looked.
              Its as if the TV had been in a time capsule.
              Caps looked like they were just pulled off the self.
              Copper coils had no sign of corrosion on...
              02-01-2023, 11:10 PM
            • Yanleb
              Hitachi Plasma TV 42HDT79 firmware upgrade
              by Yanleb
              Do you know where I can find a firmware upgrade for the Hitachi 42HDT79 plasma TV? My set currently has firmware V0112.0001.
              Their service website seems to be on SalesForce now, which requires a login.
              Thanks.
              11-05-2021, 11:55 PM
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
            • canadaboy25
              Hitachi 55HDX99 Plasma Powers on but no picture
              by canadaboy25
              Hey guys, I recently acquired a Hitachi 55HDX99 plasma TV that doesn't work. The TV powers on and eventually goes into standby which is indicated by the blue power led changing to orange. If I plug a VCR into it to keep it awake, I can feed an audio source in and it will play the sound no problem. The volume controls on the TV work as well so it is obviously just a display problem.
              I found the Hitachi service manual online which is also hosted on tom66's manual archive. Compared to the Panasonic service manual I had for the last plasma I worked on, this one is underwhelming to say...
              03-22-2019, 12:06 AM
            • Howard_Woodard
              Hitachi 42HDT52 Plasma TV - HDMI initially has no sound on Power-up
              by Howard_Woodard
              Hi all. Up until 3 years ago I used component video as the connection between my Comcast cable box and this TV and never had any issues with it -- it always worked perfectly. Then I upgraded my cable service and the new box had only an HDMI connection. The Comcast remote controls both the cable box and the TV. About 50% of the time, when I would first turn the TV on I would get video but no sound. After trying new cables, a new cable box, and switching between the two HDMI ports had made no difference, I changed the video source to see if that made any difference. It did not but I did notice that...
              02-21-2021, 12:49 PM
