Hitachi Plasma TV 42HDT79 firmware upgrade
  • Yanleb
    • May 2017
    • 102
    Do you know where I can find a firmware upgrade for the Hitachi 42HDT79 plasma TV? My set currently has firmware V0112.0001.
    Their service website seems to be on SalesForce now, which requires a login.
    Thanks.
  • Bazilwrc164
    Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
    by Bazilwrc164
    I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
    The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
    I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
    If anyone can provide:
    • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
    • Or a compatible EEPROM dump
    07-23-2025, 12:15 PM
  • massimomax
    Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
    by massimomax
    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
    spero che qualcuno può averlo per riprogrammare eprom. grazie
    Post in English !!!
    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
    02-28-2025, 07:27 AM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
  • PNI E.
    firmware hitachi 50hk6000 mainboard 17mb130s
    by PNI E.
    hi guys, can you help me to find a firmware for my hitachi 50hk6000. the tv turns on but no screen, im sure it s a firmware problem because i bought a new main board from ebay but they gave me an other version of the mainbord mine finish in s the board they gav me finish in p, and have 3 hdmi, but the tv with that board turns on but says dont signal and doesnt respond to the remote control. so someon can give me the firmaware for 50hk6000 main board 17mb130s so i can flash the eprom thansk guys
    02-14-2025, 02:06 PM
  • digitel
    Hitachi 43HAE4251 firmware
    by digitel
    Please, do you have the firmware for a Hitachi 43HAE4251 TV, with Mainboard 17MB171 and Panel VES430UNDH-N2-N45 The memory is not SPI Flash. It's EMMc. Thank you.
    07-09-2025, 01:10 AM
