Hitachi Plasma TV P42T501
  • cbrian
    • Oct 2015
    • 5
    I'm having a really odd issue with my Hitachi Plasma TV, I'd really appreciate it if anyone has any advice. Last weekend it was working fine - I turned it off, left for a couple hours, came back, and all of a sudden it no longer worked correctly. It will turn on - the screen is illuminated, and I can open the menu, change the volume, and even enter channel numbers. But there is no input at all. If I press the input button on the remote, the light on the TV flashes to indicate it gets the signal, but it won't actually open the input menu or ever show anything. I've tried resetting the software which didn't seem to help. Now it's just unplugged - I've heard that can "reset" the TV once the battery loses power. I haven't tried calling anyone to repair it as it would likely cost more than it's worth.
    Both the TV manual and my google-fu have failed me - anyone have any insight?
  • R_J
    • Jun 2012
    • 9607
    Re: Hitachi Plasma TV P42T501
    What is the software version? the latest is 0116.0001 The file name is EDAM1161.zip dated 05/27/2009, You would need an SD card to update it.
    • cbrian
      • Oct 2015
      • 5
      The software version is V0107.0001. I'm pretty sure the previous owner never updated it after buying it so it must be pretty old. However, the TV requires an MMC card instead of an SD card. Do you think there's a good chance updating would fix the issue? It looks like I could probably buy an MMC card/card reader for less than $20.
      • R_J
        • Jun 2012
        • 9607
        I should have checked the file first, Yes its a mmc card not sd card, will it fix the problem??? I do not know. Most mfgr's never tell you what the update actually fixes.
        That is the file direct from the Hitachi web site.
        • cbrian
          • Oct 2015
          • 5
          Well, just in case anyone with the same issue digs up this thread -
          I left the TV off for about a week, when I turned it on again the internal battery had died and reset the software (I presume) and it now seems to be working fine.
          In the mean time, I had bought an MMC card and put the firmware update on it but I've been unable to update the TV. It definitely recognizes the card, as well as the firmware, but when I hit update the progress bar gets to ~5% and it says "Update failed. Please turn off TV and try again". A little annoying, but at least I can use the TV again.
          Edit: I guess I spoke too soon. After turning it off and on a couple times trying to upgrade it, I'm having the same issue again - won't let me change inputs. Guess it's another week of leaving it off...
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • KYBOSH
            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
            by KYBOSH
            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
            No picture but you hear the TV static (white noise) playing loud and clear.
            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
            But it seems they didn't get too far and just left it.
            When I first took a look I was amazed at how pristine the inside looked.
            Its as if the TV had been in a time capsule.
            Caps looked like they were just pulled off the self.
            Copper coils had no sign of corrosion on...
            02-01-2023, 11:10 PM
          • Yanleb
            Hitachi Plasma TV 42HDT79 firmware upgrade
            by Yanleb
            Do you know where I can find a firmware upgrade for the Hitachi 42HDT79 plasma TV? My set currently has firmware V0112.0001.
            Their service website seems to be on SalesForce now, which requires a login.
            Thanks.
            11-05-2021, 11:55 PM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
          • Retro140
            Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
            by Retro140
            So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
            To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
            06-18-2023, 06:13 PM
