Luxor led55fsb won't start after lightning
  • karlssonw
    • Oct 2015
    • 7
    • sweden
    I'm having some trouble finding spare parts for my TV after lightning struck it trough the hdmi or rj45 jack, the TV won't power up and I can't seem to find the exact mainboard to replace it (vestel 17mb91, p/n 23239998). However i can find some finlux models that's based on the same mainboard but im not sure it will work in my TV.
    Does anybody have any experience with the compatability between vestel based TV's?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Luxor led55fsb won't start after lightning
    Do the finlux models work with the same panel ? With these Vestel sets you need to get the Mainboard Panel numbers exactly correct.
    • karlssonw
      • Oct 2015
      • 7
      • sweden
      This board is claimed to work with the panel "ves550unes-2d-s01" but there are a few extra conectors and the partnumber is not exactly the same.
      http://www.ebay.com/itm/MAIN-BOARD-1...item3d0391f19d
      The board is for the Finlux 55F9076-T which is a "3d tv" and mine is a regular 2d, is it possible to change the firmware on the new board to the luxor led55fsb firmware?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        It wont work then I will try and find you one.
        • afrim112
          • Jun 2019
          • pristina
          need dump for this chasi 17mb91
          • FlailingEngineer
            Help with Bush Tv (Vestel 17mb95m Mainboard)
            by FlailingEngineer
            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
            05-31-2023, 06:52 AM
          • porfyriadhs
            Vestel 17mb230 mainboard.No Sound
            by porfyriadhs
            Hello to everyone . I have a vestel mainboard 17mb230 with no sound on the speakers only on the headphones . I think that hotel mode is on but I cant find a way to fix .. Any help will be good thanks
            03-19-2024, 01:12 AM
          • KevinWysocki
            Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
            by KevinWysocki
            Hi there,
            My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
            At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
            After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
            Flash upgrade didn't seem to work,...
            08-20-2023, 09:45 AM
          • Aivar1988
            Can I use different VESTEL panel on mainboard?
            by Aivar1988
            Is it possible to replace any part at all in a Vestel TV with a slightly different part?
            For instance a screen panel - VES650QNTB-2W-U11 <-> VES650QNTS-2D-U11
            Or a mainboard 17MB130P for any other 17MB130P as long it had the same screen size or even the same screen panel? For example I have a 65" JVC and can I replace it with a 65" Telefunken or Hitachi mainboard. Will I need the new remote aswell? And is it possible to install the JVC firmware onto the new mainboard later?
            09-14-2021, 12:55 PM
          • piernov
            Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
            by piernov
            Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
            I suspect corrupt firmware but I haven't been able to find anything for this TV.
            TV model: Finlux 65-FUC-8060
            Mainboard: Vestel 17MB130S 23473048
            Panel: VES650QNTS-2D-U11
            At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
            06-01-2024, 12:57 PM
