Sharp LC-40LE550U no backlight
    replied
    Re: Sharp LC-40LE550U no backlight
    Originally posted by Markpixley
    Pins 8,9,10,11, and 14 all connect and join up to the (-) of the large 450v47uF capacitor...
    Pin 8 is N.C, No Connection, not used.
    Pin 9 LED 3, not being used so it is Grounded.
    Pin 10 LED 4, not being used so it is Grounded.
    Pin 4 & 11 are GND pins.
    Pin 14 IS GND pin.
    replied
    The LEDs light up because return pin for the LED return is grounded so the ineternal MOSFET and the internal current sensing are bypassed.
    I still believe that 340vdc feeding the LED string is too low. You need to find that FB pin 1 divider resistors to find out what the actual Voltage for the LEDs should be.
  • Markpixley
    replied
  • Markpixley
    replied
    Well my quickest reply is the back light does NOT come on when shorting 13>>>12
    ONLY when shorting 12>>>Ground or 13>>>ground...makes no difference which one...
    9/10 are soldered to the ground plane they have no other connection they are all connected to the ground pin (8) on the same plane...I am pretty sure after inspecting this board it is only using outputs 13/12...
    My voltage readings on the Cn202/203...
    340>>>drops to 339
    287>>>>drops to 271
    243>>>>>drops to 203
    181>>>>>>drops to 135
    129>>>>>>>drops to 67
    78>>>>>>>>>drops to .04
    the only other difference I read is pin 7 (slp) sits at .99 until I short 12/13>>>grnd then it goes to 1.3v
    replied
    OK, that IC is the 4-Channel LED driver.
    Pin 13 is LED string 1 Cathode return
    Pin 12 is LED string 2 Cathode return
    Pin 9 is LED string 3 Cathode return
    Pin 10 is LED string 4 Cathode return
    The Cathodes return currents flow through 4 internal MOSFETs inside the IC and then to GND pin of the IC. See app notes AN006 PDF page 2 attached.
    The circuit in this board does not have the Cathode return connected to pin 12 (LED2), it has the Cathode return of the LED string connected to the Drain pin of the Power MOSFET UD103, then Source pin is then connected to pin 12 (LED 2) and then the LED current will then flow through the internal MOSFET IC pin 12 and goes out to GND pin.
    So if you connect pin 12 (LED 2) to pin 13 (LED 1) and you get backlights, then it means that the current sink circuit for LED 2 is bad and you are using pin 13 (LED 1) as the current sink path for the LED string. To proof that you will have to take out pin 12 and use pin 13 only.
    You have 4 current sink for 4 LED strings, the board is using only one (pin 12 LED 2) of the four, so if pin 12 LED 2 bad (bad internal MOSFET?)and you shift the current circuit to pin 13 LED 1 instead and it works then you are in business.
    I also would like to know what the Boosted Voltage is now since the LEDs light up now.
    It looks me that they use external power MOSFET in series with the internal MOSFET to reduce heat dissipation of the IC.
    Bottom line, try shifting the circuit to pin 13 see what happen, pin 12 has to be removed from the circuit, leave pin 9, 10 alone.., then check the DCV feeding the LED to see if it is >340VDC, also the DCV for FB pin, need to find out where the FB pin is connected to in the circuit, if it is still way above 3V then you need to check that Voltage divider on that output of the 390V to see if the resistor to GND of the Voltage divider may have gone up in resistance. See page 6 of the APP NOTE AN006 PDF page 6. It can be that the FB is so high so the output Voltage is only 340VDC instead of higher Voltage. If you can find that Voltage divider resistors then you can calculate what the output Voltage for the LED should be, the formula is also on that page 6.
  • Markpixley
    replied
    So this is where I am at...the FB pin (1) was getting 12.28 volts...waaay to much as far as I can tell...by jumping pins 13/12 to ground it dropped the voltage on FB to 1.9 which is below the high tolerance set (3.3) basically I forceed the FB to low and everything works...now I need to figure out if it is the UD101 or the circuit from the FB pin ...
  • Markpixley
    replied
    So further testing...
    By jumping pins 13>>>10 and 12>>>9 o the UD101 I was able to get the backlight to light up...
    I have 13.58 volt on 13/12 and none on 9/10
    9/10 are not connected to anything except ground, so basically forcing 13/12 to ground turns on the back light...
  • Markpixley
    replied
    Originally posted by budm
    So what is the P/N of the UD101?
    P/N for UD101 is RT8300
    http://www.richtek.com/en/Products/L...0Driver/RT8300
    replied
    replied
    Right now the BLON is high enough to turn on the BL power supply to put out the boosted Voltage but at this point that 340VDC may be too low.
    I need to study the function of UD101 to see how it works.
  • Markpixley
    replied
    Post1, and 2, plan 14 is the BLON which must be working otherwise you will not see the LED supply Voltage jump up from 89V to 240Vdc.
    Thanks, budm, so now that I think about it, he had 3 volts there PRIOR to finding his short and his was off? I have <3v which means it is on...?
    Or am I backwards?
    I get what you mean about the supply voltage but is it possible that the ricoh chip (UD101) drops the current when it find a led fault/short/open to below "strike" threshold for the lamps? (I know thats not what happens here but its the basic idea)
    "On most sets, BL_ON (backlight on) going high (> 3) means turn on. On some sets, it might be the opposite.
    replied
  • Markpixley
    replied
    Sooo...further testing pin#13 (Back light On) I'm getting .224 volts...basically minimal perhaps even ghost read...the guy in the first post had 3 volts here...
    replied
    Yes its actually a little more each string has eleven led's so the voltage required is 66volts...
    So it has 55 LEDs to total then? If that is the case, then the 340VDC (329V) for the LED string is too low, 55 LEDs will need 330V + Vdrops on the MOSFET + V drops on the current sensing resistor.
  • Markpixley
    replied
    I flipped the psu over and have it plugged in, powered up and the Mosfet QD101 reads 12.44v bottom leg at left, 14.17v bottom leg right (same as pin 13 on UD101) and 79.2v (same as Cn203 pin 5/bottom rail of led return)
  • Markpixley
    replied
    Looking at those reading for the Vf of each string, for example: the first string is 340 - 286 = 54V, so average Vf of each sting is about 52V which is not right since ten 6V LED should be 60V per string.
    It looks like the MOSFET QD101 is not being turned on.
    I need to look up the spec the IC UD101 to see how it function.
  • Markpixley
    replied
    So far the info I have gathered on the niko is it is not schothy or esr, it can maintain up to 800 rds volts on 10v...seems like it goes up to 4 amps 512 pf Ciss typical...
    replied
    the voltage to Cn202/cn203=
    1. (+) 340
    2. (-) 286
    3. (+) 286
    4. (-) 233
    5. (-) 233
    1. (-) 180
    2. (+) 180
    3. (-) 128
    4 (+) 128
    5. (-) 77.8
  • Markpixley
    replied
    OK, so there is no open connection on the LED strings, and you can get all the LEDs in each strip to light up OK.
    Forgive me for being dense (Thick as a brick per Jethro Tull)...
    I start with 340 volts and end with 76 but no light...so where in hell is all that voltage going?...if it was open I would not see any voltage at the last pin...
    If there is a short...?
  • Markpixley
    replied
    Correct...now here's a question...
    The Rich Tek chip (UD101)
    Pins 13/12 each show 10 volts (led 1/2)
    Pins 10/9 show no voltage (.004) which would be led 4/3
    Vin is 12v
    Fault is 12v
    Is this chip ONLY being used for two led diagnostics? and pins 10/9 would never be used anyway?
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
  • Misterfixit
    Sharp LC-58Q7330U No Backlight
    by Misterfixit
    This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
    06-04-2023, 07:39 PM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • Misterfixit
    sharp LC-50LB601U No backlight
    by Misterfixit
    I have a sharp LC-50LB601U that has no backlight. It starts up fine, and has sound, however, I can only see the screen using a flashlight. I took the tv back off and measured voltages at the power supply connector CN-8601. As you can see by the picture, the led connector has 2 sets of 2 red wires and 2 sets of black wires going to the led backlights. Between each set of black wires and corresponding red wires, I measure 30 volts (pins 1 and 4) and 30 volts from pins 8 and 12. From ground to each set of red wires ( pins 1 and 12 to ground), I measure 35 volts. This voltage seems very low compared...
    04-04-2023, 01:21 PM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
